FlyingDude Posted July 7, 2024 Report Posted July 7, 2024 Hi, What's the font used for these markings? Whatthefont app returned Mad Cash. Does anyone know for sure? Is that correct? Thanks. Quote
Fly Boomer Posted July 7, 2024 Report Posted July 7, 2024 15 minutes ago, FlyingDude said: What's the font used for these markings? Whatthefont app returned Mad Cash. Does anyone know for sure? It's possible that no computer fonts were involved with that lettering. Was your AFM/POH prepared with a word processor? Quote
N201MKTurbo Posted July 7, 2024 Report Posted July 7, 2024 Considering the age, it is probably from a plastic draftsmen’s lettering template. Quote
MikeOH Posted July 8, 2024 Report Posted July 8, 2024 Given the time frame (early '60s) it's likely Helvetica (late '50s font design). Arial came along in the computer era as a substitute for Helvetica; I think there were licensing issues so a new font was developed just enough different to avoid infringement. All the above IMHO N201MK Turbo's lettering guide theory could be a better guess Quote
redbaron1982 Posted July 8, 2024 Report Posted July 8, 2024 Looks similar to ETA switches, the font is "din 1451 mittelschrift std" 1 1 Quote
PT20J Posted July 8, 2024 Report Posted July 8, 2024 Masters for silkscreens of that vintage were often made from sheets of press on letters. 1 Quote
FlyingDude Posted July 8, 2024 Author Report Posted July 8, 2024 8 hours ago, redbaron1982 said: Looks similar to ETA switches, the font is "din 1451 mittelschrift std" No, the capital G doesn't match. 1451 has rounded bottom right corner. The panel font is square. Quote
N201MKTurbo Posted July 8, 2024 Report Posted July 8, 2024 Another thing is the spacing of the W and A. They are nested together. Computer fonts don’t usually do that. 1 Quote
N201MKTurbo Posted July 8, 2024 Report Posted July 8, 2024 6 hours ago, PT20J said: Masters for silkscreens of that vintage were often made from sheets of press on letters. I think it was 91 when I did my last PCB layout with press on symbols and letters. 1 Quote
redbaron1982 Posted July 8, 2024 Report Posted July 8, 2024 18 minutes ago, FlyingDude said: No, the capital G doesn't match. 1451 has rounded bottom right corner. The panel font is square. That's true, how about this one: Quote
FlyingDude Posted July 8, 2024 Author Report Posted July 8, 2024 25 minutes ago, redbaron1982 said: That's true, how about this one: No, the way R's leg separates is different. Quote
redbaron1982 Posted July 8, 2024 Report Posted July 8, 2024 If you get a good picture with the text not skewed and not rotated, you could try to use https://www.fontspring.com/matcherator. If you want, send me a better picture, and I can run it through that app to see if there is a better match. 1 Quote
FlyingDude Posted July 8, 2024 Author Report Posted July 8, 2024 @redbaron1982 thanks. I'll give it a shot. Quote
redbaron1982 Posted July 8, 2024 Report Posted July 8, 2024 Maybe Alternate Gothic? G, R, and K matches. Also M. 1 Quote
Pinecone Posted July 8, 2024 Report Posted July 8, 2024 2 hours ago, N201MKTurbo said: Another thing is the spacing of the W and A. They are nested together. Computer fonts don’t usually do that. It is called "kerning" and computer fonts can do that. But not old fonts and old systems. like this WA Quote
