JoeM Posted May 30, 2024 Report Posted May 30, 2024 (edited) Anyone who has installed a G5 magnetometer in a short body willing to fabricate one for me? I am getting ready to install dual g5s under IA supervision and would prefer to use someone's successful installation bracket rather than fabricate from scratch. TIA Edited May 30, 2024 by JoeM Quote
bcg Posted May 30, 2024 Report Posted May 30, 2024 I just bent a small piece of scrap aluminum that my IA had in the shop on the brake and drilled some holes in it. I had to play with the angle a little to get it level. I don't think it took me more than an hour to work it all out, there's really not much to it.Sent from my Pixel 6a using Tapatalk Quote
McMooney Posted May 30, 2024 Report Posted May 30, 2024 mine is just a stiff piece of aluminum in the tail, not much to fabricate. your IA/AP could make short work of it Quote
flyboy0681 Posted May 30, 2024 Report Posted May 30, 2024 When my magnetometer was installed in the tail, we could not get a single accurate calibration. Eventually it had to be moved to under the wing, where it now gives me precise readings. Here's a picture from its original location. Quote
Aerodon Posted May 30, 2024 Report Posted May 30, 2024 I have made up a few of these for wing mounting GMU11's. I did a fuselage mount similar to the one above, but with a support. I don't like what I see there, it's like mounting the GMU11 on a tuning fork. Also, I don't like drilling new holes in stringers. It worked for the calibration, but from time to time I'd get an error because of loss of signal. Wing mount works good, but plan on running light and strobe grounds to well inboard of the magnetometer. Aerodon 3 Quote
Skates97 Posted May 30, 2024 Report Posted May 30, 2024 My plane had an ancient magnetometer in a bracket that spanned side to side. It was already level so I just cut a piece of aluminum to mount the G5 magnetometer to and mounted it to the bracket. 1 Quote
Fly Boomer Posted May 30, 2024 Report Posted May 30, 2024 18 hours ago, McMooney said: mine is just a stiff piece of aluminum in the tail, not much to fabricate. your IA/AP could make short work of it What's the "handle bars" gizmo on top? Quote
McMooney Posted May 30, 2024 Report Posted May 30, 2024 1 hour ago, Fly Boomer said: What's the "handle bars" gizmo on top? Brittain magnetometer 1 Quote
McMooney Posted May 31, 2024 Report Posted May 31, 2024 honestly, you wouldn't believe how sensitive those things are, mine in the tail can detect a person walking by the plane within about 3 feet. while all testing was well within range, it was very noticeable when i tested standing near the tail and when i was out by the wing Quote
Vance Harral Posted May 31, 2024 Report Posted May 31, 2024 20 hours ago, Aerodon said: I have made up a few of these for wing mounting GMU11's. I heartily endorse Aerodon's GMU11 mount! Worked perfectly to mount our GMU11 in the wing. Quote
