The landing gear bulb burnt out and my partner pulled this out of the panel. When I conduct a search on the part number, CM7338, the mount is completely different. What is the correct part number?
28 minutes ago, PT20J said:
It looks like the current Chicago Miniature 28V bulbs are either a 7387 (3 mm pin spacing) or a 7839-2 (2.5 mm pin spacing). https://cml-it.com/us/products/lamps-signalisation/bi-pin/pin-abstand-254mm/
International Avionics makes the annunciator panel. You could call them to verify. https://www.internationalavionics.com
Thanks for the replies guys..
This is so very confusing. How could the two pin be mislabeled?
I'll contact International and see what they say. Stay tuned.
It's certainly not mislabeled. But it could well be an obsolete part superseded by a newer part, or simply discontinued. This happens all the time especially with parts that are 41 years old. :)
Good point.
I’ve got a few of these from my J annunciator panel (28V) which I could mail you. I’ll check part # over the weekend and post it.
