TGreen Posted April 11, 2024 Report Posted April 11, 2024 Starting to look into an overhaul for my IO-550-G. Some shops have said they won't even quote or commence an overhaul because the cylinders (I think the part no. is 655474) are not available and they don't really know when they will become available. Has anyone else encountered this? Any advice? Quote
Bolter Posted April 11, 2024 Report Posted April 11, 2024 Following, because it is only a matter of time before I will contemplate overhaul. Does rebuilding the cylinders avoid any of the supply chain issues? 1 Quote
rickseeman Posted April 21, 2024 Report Posted April 21, 2024 Rebuild? You mean like everybody did for 50 years before they got cylinder-replacement-happy? You would have to grind the valves and seats. Isn't it easier to just open the box on a new one and charge the customer $1,700 extra? 2 Quote
Alan Maurer Posted April 21, 2024 Report Posted April 21, 2024 Is there more to rebuilding a wearing out cylinder than grinding the valves and seats. What about restoring the honing on the cylinder walls or checking the valve guides? I find myself adding more oil than a year ago. Good question to wonder about? Alan 1 Quote
Niko182 Posted April 21, 2024 Report Posted April 21, 2024 Is there a difference in availability with the N compared to the G cylinders? Maybe it may be worthwhile going the N route. 1 Quote
rickseeman Posted April 21, 2024 Report Posted April 21, 2024 1 hour ago, Alan Maurer said: Is there more to rebuilding a wearing out cylinder than grinding the valves and seats. What about restoring the honing on the cylinder walls or checking the valve guides? I find myself adding more oil than a year ago. Good question to wonder about? Alan He will check the guides too. If it needs guides I wouldn't think that would be a big deal. I hone a lot of car cylinders. A guy that rebuilds cylinders it set up for this and can do it in a few minutes. In the old days people didn't just "buy new cylinders" You just fix it. It wasn't rocket science. 1 Quote
Bolter Posted April 22, 2024 Report Posted April 22, 2024 10 hours ago, Niko182 said: Is there a difference in availability with the N compared to the G cylinders? Maybe it may be worthwhile going the N route. As a fellow 310 HP STC holder, I wonder about this. Can you put an N to replace the G? I did not research it, but it seemed to me that the G with the higher rpm is the approved engine, not an N with 2700 rpm and 310 HP. The N should fit and work, but it is not the same engine. -dan 1 Quote
StevenL757 Posted April 22, 2024 Report Posted April 22, 2024 (edited) 9 hours ago, Bolter said: As a fellow 310 HP STC holder, I wonder about this. Can you put an N to replace the G? I did not research it, but it seemed to me that the G with the higher rpm is the approved engine, not an N with 2700 rpm and 310 HP. The N should fit and work, but it is not the same engine. -dan I’ve replaced two “G” engines with the IO550N. As long as one possesses the 310hp STC and your governor has been adjusted to the T20 standard, you’re approved to install the “N” engine (out of the box as 2700RPM / 310BHP) either as factory-new or factory-reman. Both have 2200-hour TBOs and zero-time logbooks, and are considered “approved”. The “N” engine is actually flat-rated to nearly 338hp, but is de-rated to 310. It is considered slightly more powerful than the “G”, per Minnis Aviation’s test criteria back when Bob Minnis established that STC. The “G” cylinder baffles are straight; whereas, the “N” baffles are tapered; the latter requiring a couple of sheet metal wedge pieces to fill gaps left behind that the “G” cylinders take up naturally by their straight baffle design. Steve Edited April 22, 2024 by StevenL757 3 1 Quote
Bolter Posted April 22, 2024 Report Posted April 22, 2024 1 hour ago, StevenL757 said: I’ve replaced two “G” engines with the IO550N. As long as one possesses the 310hp STC and your governor has been adjusted to the T20 standard, you’re approved to install the “N” engine (out of the box as 2700RPM / 310BHP) either as factory-new or factory-reman. Both have 2200-hour TBOs and zero-time logbooks, and are considered “approved”. The “N” engine is actually flat-rated to nearly 338hp, but is de-rated to 310. It is considered slightly more powerful than the “G”, per Minnis Aviation’s test criteria back when Bob Minnis established that STC. The “G” cylinder baffles are straight; whereas, the “N” baffles are tapered; the latter requiring a couple of sheet metal wedge pieces to fill gaps left behind that the “G” cylinders take up naturally by their straight baffle design. Steve Excellent information. Great to have more options. 1 1 Quote
Niko182 Posted April 22, 2024 Report Posted April 22, 2024 (edited) 1 hour ago, StevenL757 said: I’ve replaced two “G” engines with the IO550N. As long as one possesses the 310hp STC and your governor has been adjusted to the T20 standard, you’re approved to install the “N” engine (out of the box as 2700RPM / 310BHP) either as factory-new or factory-reman. Both have 2200-hour TBOs and zero-time logbooks, and are considered “approved”. The “N” engine is actually flat-rated to nearly 338hp, but is de-rated to 310. It is considered slightly more powerful than the “G”, per Minnis Aviation’s test criteria back when Bob Minnis established that STC. The “G” cylinder baffles are straight; whereas, the “N” baffles are tapered; the latter requiring a couple of sheet metal wedge pieces to fill gaps left behind that the “G” cylinders take up naturally by their straight baffle design. Steve How is the N variant de rated from 340hp? Just max rpm? Edited April 22, 2024 by Niko182 1 Quote
PMcClure Posted July 24, 2024 Report Posted July 24, 2024 On 4/22/2024 at 8:56 AM, StevenL757 said: I’ve replaced two “G” engines with the IO550N. As long as one possesses the 310hp STC and your governor has been adjusted to the T20 standard, you’re approved to install the “N” engine (out of the box as 2700RPM / 310BHP) either as factory-new or factory-reman. Both have 2200-hour TBOs and zero-time logbooks, and are considered “approved”. The “N” engine is actually flat-rated to nearly 338hp, but is de-rated to 310. It is considered slightly more powerful than the “G”, per Minnis Aviation’s test criteria back when Bob Minnis established that STC. The “G” cylinder baffles are straight; whereas, the “N” baffles are tapered; the latter requiring a couple of sheet metal wedge pieces to fill gaps left behind that the “G” cylinders take up naturally by their straight baffle design. Steve Hi Steve - we are in the process of replacing our G with a new N with the STC. Is there a drawing for the metal wedges? The STC mentions drawings but we could not find them. Quote
PMcClure Posted July 24, 2024 Report Posted July 24, 2024 On 4/11/2024 at 6:18 PM, TGreen said: Starting to look into an overhaul for my IO-550-G. Some shops have said they won't even quote or commence an overhaul because the cylinders (I think the part no. is 655474) are not available and they don't really know when they will become available. Has anyone else encountered this? Any advice? I am replacing my G with a N. After working with TCM for months we found it was the only viable option as TCM is phasing out several G series engines. I took off the G series cylinders that only had about 400 hours and replaced them with the original ones to send back with the core. Only later realizing that I could not use them on the new G. So now I have a set of G cylinders with 400 hours on them. Quote
PMcClure Posted July 24, 2024 Report Posted July 24, 2024 On 4/21/2024 at 11:40 PM, Bolter said: As a fellow 310 HP STC holder, I wonder about this. Can you put an N to replace the G? I did not research it, but it seemed to me that the G with the higher rpm is the approved engine, not an N with 2700 rpm and 310 HP. The N should fit and work, but it is not the same engine. -dan Part of the STC includes a "N" engine plate to attached to your G engine after making the required changes. 1 Quote
Phil EF Posted July 24, 2024 Report Posted July 24, 2024 Ram has a range of overhauled new and repaired cylinders for the 550C. May have something for other variants. Quote
StevenL757 Posted July 25, 2024 Report Posted July 25, 2024 13 hours ago, Phil EF said: Ram has a range of overhauled new and repaired cylinders for the 550C. May have something for other variants. The 550C is not an approved engine model for the Ovation. Quote
StevenL757 Posted July 25, 2024 Report Posted July 25, 2024 20 hours ago, PMcClure said: Hi Steve - we are in the process of replacing our G with a new N with the STC. Is there a drawing for the metal wedges? The STC mentions drawings but we could not find them. Yes. Bob Minnis would be a starting point for the drawings. Brian Kendrick can lend a hand also. 1. Bobminnis@comcast.net 2. Brian@mooneysupport.com Quote
William Munney Posted July 28, 2024 Report Posted July 28, 2024 I just bought a factory NEW IO550G from Continental last Winter. They had factory remanufactured engines available also. Cornering the market on G cylinders? Quote
TGreen Posted August 3, 2024 Author Report Posted August 3, 2024 Got a call from Air Power during Oshkosh saying they had six new cylinder assemblies available. Bought them on the way home and will be starting overhaul at Western Skyways soon! Quote
Fly Boomer Posted August 3, 2024 Report Posted August 3, 2024 2 hours ago, TGreen said: Got a call from Air Power during Oshkosh saying they had six new cylinder assemblies available. Bought them on the way home and will be starting overhaul at Western Skyways soon! How long did you wait? Your last post in April said you were trying to figure out what to do. Quote
TGreen Posted August 5, 2024 Author Report Posted August 5, 2024 A long time. Think I placed an order with Air Power in April or May. Never really got comfort that Continental was producing any cylinders for the IO-550-G, but then six of them showed up at Air Power. 1 Quote
