GeeBee Posted October 6, 2023 Report Posted October 6, 2023 This will be interesting. The 757 has a fairly simple gear system, and the alternate extension is even simpler. The alternate uses 28v battery power to power a small hydraulic pump that unlocks the gear doors, pushes the over center just far enough to allow the down springs do drop and lock the gear. The only thing I can think of is loss of the left hydraulic system, then the alternate system failed somehow.
MikeOH Posted October 6, 2023 Report Posted October 6, 2023 Yeah, but the real question is how much 1980Mooney’s insurance is going to go up! 1 3
N201MKTurbo Posted October 6, 2023 Report Posted October 6, 2023 2 hours ago, GeeBee said: This will be interesting. The 757 has a fairly simple gear system, and the alternate extension is even simpler. The alternate uses 28v battery power to power a small hydraulic pump that unlocks the gear doors, pushes the over center just far enough to allow the down springs do drop and lock the gear. The only thing I can think of is loss of the left hydraulic system, then the alternate system failed somehow. How about they forgot to put the handle in the down position?
N201MKTurbo Posted October 6, 2023 Report Posted October 6, 2023 17 minutes ago, N201MKTurbo said: How about they forgot to put the handle in the down position? I just heard the news report where they said they tried for a while to get the wheels down, so I apologize to the FedEx crew.
MooneyMitch Posted October 6, 2023 Report Posted October 6, 2023 WOW! That sure made a lot more sparks than a Mooney gear up!! ...............and at night too.............spectacular sight!!! No wonder my FedEx package delivery was late................. 2
tmo Posted October 6, 2023 Report Posted October 6, 2023 Hey, cut them some slack, at least they didn't just pull the chute! 2
EricJ Posted October 6, 2023 Report Posted October 6, 2023 Will definitely be interesting to see what happened here. Might be a maintenance failure. Won't be surprised if the airplane returns to service.
GeeBee Posted October 6, 2023 Author Report Posted October 6, 2023 Looks like wreckage is cleared as the runway NOTAM has been cancelled
MikeOH Posted October 7, 2023 Report Posted October 7, 2023 4 hours ago, tmo said: Hey, cut them some slack, at least they didn't just pull the chute! But I bet they said, "Oh, chute!!"...or something similar 1
GeeBee Posted October 8, 2023 Author Report Posted October 8, 2023 My guess is they had a leak in the left hydraulic reservoir below the standpipe level that completely emptied the reservoir and left the emergency pump dry.
Ragsf15e Posted October 21, 2023 Report Posted October 21, 2023 https://abcnews.go.com/Business/wireStory/ntsb-fedex-plane-disabled-landing-gear-suffered-leak-104185678 make sure your backup system is working when you have the chance!
EricJ Posted October 21, 2023 Report Posted October 21, 2023 2 minutes ago, Ragsf15e said: https://abcnews.go.com/Business/wireStory/ntsb-fedex-plane-disabled-landing-gear-suffered-leak-104185678 make sure your backup system is working when you have the chance! They're supposed to do gear swings and backup checks during their approved inspection schedule, probably annually or so like we do. I'm sure in the final report there'll be more info on how the backup failed. Definitely unusual, and I'm curious to see what happened. 1
