GaryP1007 Posted August 16, 2023 Report Posted August 16, 2023 Updating my G1000 and for some reason the unit now does not recognize the terrain download. I downloaded it twice, using two new data cards, and still nothing. Could I have done something wrong? Sent from my iPhone using Tapatalk
LANCECASPER Posted August 16, 2023 Report Posted August 16, 2023 44 minutes ago, GaryP1007 said: Updating my G1000 and for some reason the unit now does not recognize the terrain download. I downloaded it twice, using two new data cards, and still nothing. Could I have done something wrong? There are a couple options on the Garmin site for Terrain database, however terrain doesn't change often so you don't have to update very often. Make sure that if you did download an update that you downloaded the correct one. If you have Synthetic Vision then you need the larger Terrain Database (higher resolution), 4.9 I believe. 2
GaryP1007 Posted August 16, 2023 Author Report Posted August 16, 2023 There are a couple options on the Garmin site for Terrain database, however terrain doesn't change often so you don't have to update very often. Make sure that if you did download an update that you downloaded the correct one. If you have Synthetic Vision then you need the larger Terrain Database (higher resolution), 4.9 I believe.Thank you. Sent from my iPhone using Tapatalk
GaryP1007 Posted August 16, 2023 Author Report Posted August 16, 2023 Thank you. Sent from my iPhone using TapatalkThis is what I did. Sent from my iPhone using Tapatalk
Ragsf15e Posted August 17, 2023 Report Posted August 17, 2023 (edited) Personally, since terrain doesn’t change, I don’t update it once you’ve got it working… The terrain files are really big and have caused me issues in the past. Edited August 17, 2023 by Ragsf15e
LANCECASPER Posted August 17, 2023 Report Posted August 17, 2023 54 minutes ago, GaryP1007 said: This is what I did. Sent from my iPhone using Tapatalk That number 20T1 means that it is a 2020 update so it may have over-written what you had for Terrain before that. I would call Garmin Aviation Product Support at 1-866-739-5687
GaryP1007 Posted August 21, 2023 Author Report Posted August 21, 2023 That number 20T1 means that it is a 2020 update so it may have over-written what you had for Terrain before that. I would call Garmin Aviation Product Support at 1-866-739-5687They said that was the most recent version. I re-downloaded it but still can’t get the G1000 to see it. Sent from my iPhone using Tapatalk
LANCECASPER Posted August 21, 2023 Report Posted August 21, 2023 10 minutes ago, GaryP1007 said: They said that was the most recent version. I re-downloaded it but still can’t get the G1000 to see it. Are you putting it into the top or bottom slot on your MFD?
GaryP1007 Posted August 21, 2023 Author Report Posted August 21, 2023 36 minutes ago, LANCECASPER said: Are you putting it into the top or bottom slot on your MFD? Bottom?
LANCECASPER Posted August 21, 2023 Report Posted August 21, 2023 32 minutes ago, GaryP1007 said: Bottom? That's correct. I'd get back on the phone with them and they are usually pretty good about walking you through it 1
GaryP1007 Posted August 26, 2023 Author Report Posted August 26, 2023 That's correct. I'd get back on the phone with them and they are usually pretty good about walking you through itGot one side to accept the terrain data but I can’t seem to get both. I’ve duplicated the card from the one that works but seems like something is missing. I’ll keep plugging away. Sent from my iPhone using Tapatalk
DContreras96 Posted January 28, 2025 Report Posted January 28, 2025 (edited) On 8/26/2023 at 7:40 AM, GaryP1007 said: Got one side to accept the terrain data but I can’t seem to get both. I’ve duplicated the card from the one that works but seems like something is missing. I’ll keep plugging away. Sent from my iPhone using Tapatalk Did you ever get it resolved? I am having the same problem with mine. Edited January 28, 2025 by DContreras96
GaryP1007 Posted January 28, 2025 Author Report Posted January 28, 2025 15 hours ago, DContreras96 said: Did you ever get it resolved? I am having the same problem with mine. My issue was selecting the wrong option........I needed the 9 second arc and didnt choose that correctly initially. Hope that helps.
MatthiasArnold Posted January 28, 2025 Report Posted January 28, 2025 54 minutes ago, GaryP1007 said: My issue was selecting the wrong option........I needed the 9 second arc and didnt choose that correctly initially. Hope that helps. This - the resolution must match the capabilities of your system (w/ or wo/ SVT).
Danb Posted January 28, 2025 Report Posted January 28, 2025 DC I’ve gotten that msg a few times, I go back to the computer and reload it again and it works..
