tls pilot Posted July 12, 2023 Report Posted July 12, 2023 The manual does not show the nose wheel bearings Does anyone have those or confirm the Cup 08231 Cone 08125 Thank you in advance
1980Mooney Posted July 12, 2023 Report Posted July 12, 2023 1 hour ago, tls pilot said: The manual does not show the nose wheel bearings Does anyone have those or confirm the Cup 08231 Cone 08125 Thank you in advance The OEM Mooney bearing numbers are listed on 32-40-00 in the M20M Parts Catalog. (Since you are “tls pilot”.) I looked up the cone and it cross referenced to your number but you need to double check. 1 1
OR75 Posted July 12, 2023 Report Posted July 12, 2023 section 32 of any A/C Parts Catalog is Landing Gear that way since things started being structured and "organized" (around 1977) ... manuals ... instruments (6 pack)
PT20J Posted July 12, 2023 Report Posted July 12, 2023 I believe those bearings are made by Timken. According to aircraftsupply.com, the Timken part numbers are: 214-00300 = 08231-20629 214-00400 = 08125-20629 Skip 1 1
