Currently on the crossing. Track my ident CGJOG or my inreach here https://share.garmin.com/TylerG
Posted a couple of photos. I have some great videos if someone knows the best way for me to upload those. My approach to Nuuk, Greenland, will be the most memorable of my life. Flying with a high broken cloud layer, the sun shining through, flying over a low cloud layer, and a fog bank over the entire runway except for the threshold. Amazing and beautiful.
The IRL Flight (I did this with more stops than I would have if I had gone alone or with a partner closer to my age. My dad wanted more breaks)
  • Leg 1: CZBB (Vancouver) to CYSF (Stony Rapids)
    This was a quick fuel stop. I topped off the tanks to avoid fuel in Rankin, where it's only sold by the barrel.
  • Leg 2: CYRT (Rankin Inlet)
    We stayed over here. No fuel purchase. This is the stop I would have skipped and just flown a long day CZBB - CYSF - CYFB
  • Leg 3: CYFB (Frobisher Bay/Iqaluit)
    Here, we only required one barrel on top of what was left in the tanks to get us to Nuuk. Avoid the FBO if you can and just have the fuel guy (separate from the FBO) pump your fuel. You do not need your own pump here. Flight planning from here to Nuuk was easy. I filed a direct routing, and they gave me that.
  • Leg 4: BGGH (Nuuk)
    I would have gone CYFB—BIRK on the way across and skipped Greenland. GJOG has the legs to do it with an hour+ for reserve and a slight headwind.
    This was the most beautiful approach of my life, primarily due to the sun shining through different cloud layers and the fog bank over most of the runway. The airport here was recently built. Everything was new. Clean and nice.
    Paperwork: I filed through Foreflight. For customs, I emailed the airport an hour before our departure, informed them of our arrival time, and attached copies of our passports. Customs was ready for us when we arrived, and it went smoothly. He even called us a cab to our hotel.
  • Leg 4: BIRK (Reykjavik)
    You file specific waypoints across the icecap and onto Iceland. When you send your plan to "flights" in Foreflight, it will tell you if it is valid before submitting. Mine was as follows: Nuuk - Bamam - Y47 - DA - Nasop - Nonro - Igan - Birk
    Paperwork: Filed through Foreflight. I didn't notify the airport ahead of time. Customs has a small office located next to the FBO parking. It was quick and easy. They looked at our passports and filled in a customs form.
  • Leg 5: EGPO (Stornoway)
    We spent nearly the entire crossing in the white room, so we caught up on a podcast about Vikings. We chose Stornoway over Wick because we have our own survival gear and family in Stornoway.
    Paperwork: It was a bit more involved. You have to submit a form through the airport here to request permission to land and file a GAR report to customs here. The GAR is similar to the USA eAPIS. This did make the arrival smooth. We were approved through customs before landing and didn't need to see an agent of any kind. The guy from the FBO said we were cleared, and we went straight to grab our taxi.
Hi Mooney Pilots,
I am looking for any pilots who have made the crossing recently.
Flying my FIKI-certified "Standing Ovation" with Monroy Long Range Tanks from Canada across the Atlantic to Scotland and back again.
When: August 2025 (UPDATED)
Where: Vancouver, BC to Wick, Scotland. We will likely make the crossing from Iqaluit (Frobisher Bay)
Tentative Flight Plan: Iqaluit - Nuuk - Reykjavik - Faroe Islands - Wick
Who: I will be making the journey with my pops (retired private pilot)
What: I would love any advice from experienced pilots. Everything from flight planning to gear selection. I want this flight to be as safe and successful as possible. Open to hiring a consultant.
My Kit:
Avionics/Radios
Dual G3X touch (10” and 7”)
GI260 AOA indicator (displayed on G3X)
Garmin advanced engine indication system EIS
G5 backup AI
4 axis GFC500 autopilot + controller (Roll/Pitch/Pitch Trim/Yaw)
Electronic Stability Protection (ESP)
Return-to-Level button
Takeoff/Go-around (TOGA) button
Smart Glide Button
GTN650xi WASS GPS/NAV/COM1
GNC355 WASS GPS/COM2
GMA35 remote audio panel (Telligence™ Voice Command and Bluetooth)
GTX 345DR Remote-mount ADS-B "In"/"Out" with XPDR diversity antenna
GDL 52R Remote-mount SiriusXM®/ADS-B Receiver
Additional Equipment
TKS Weeping Wing FIKI certified De-Icing System
Built-in 4-place oxygen
CiES fuel senders (for precise fuel indication)
Microkit Landing Height System (w/ gear warning system)
Speed Brakes
Tanis Engine + Battery Preheat System
I have been getting a lot of great advice and feedback. To ensure the whole community can benefit from it, I will post it here below as I go. I will also post the trip once it happens.
Flight Plannning
I will start the trip from Vancouver, BC, then cross at Iqaluit (Frobisher Bay) CYFB - Nuuk BGGH - Reykjavik BIRK - Faroe Isl EKVG (if WX Permits, low prob) - Scotland
I have created a Google Sheet Flight Plan
Read this North Atlantic International GA Ops Manual it clarifies equipment and regulatory questions
7000 VFR Sqwak EU
Safety and Survival
Raft and Immersion Suit
You can rent
Rent your raft and immersion suit from Far North Aviation; they provide both pick-it-up and drop-off on either side of the pond (Goose Bay and Wik only)
You can purchase
Winslow Ultra-Light Offshore weighs 32 lbs
Mustang Ocean Commander Immersion Suit (5-8 lbs*)
Survival Kit
4 liters of water (in kit for emerg only)
Food (in kit for emerg only)
Parachute Flares
High Powered Laser Pointer
Emergency Blanket
Down sleeping bag
Hook Knife (attached to suit)
Pocket Knife
Paracord
Jetboil
Electronics
Garmin InReach Mini w/waterprrof case
No HF - The route Iqaluit CYFB - Nuuk BGGH - Reykjavik BIRK is in VHF range and doesn't require HF
N America and EU databases for both my Garmin equipment and Foreflight
Admin
Regulations
Edited by Tyler G
uploading photos
  • Like 6
I'm planning for the same trip in my m20e,  hoping to get the long range tanks installed next year.  good autopilot the year after.
Edited by McMooney
4 hours ago, Tyler G said:
Hi Mooney Pilots,
I want to fly my FIKI-certified "Standing Ovation" with Monroy Long Range Tanks from Canada across the Atlantic to Scotland and back again.
When: Sometime this summer 2023
Who: I will be making the journey with my dad (retired private pilot)
Thanks in advance,
Tyler
A client of mine has done the crossing starting in Ontario at least seven times, once in his Mooney and many more in his C340.  PM me and I can connect you with him.
Another who has done the crossing many times in his Mooney.
https://www.zahorsky.net/blog/
I did the crossing in 2003. See my photo for me in an immersion suit on my way over to Europe.
You should definitely do this. It is a blast.
You need an immersion suit. You need to have it on when you're flying (but not the top part, as flying with it covering your hands would be uncomfortable and challenging) so that if you have to ditch you will have time to get into your raft before freezing to death in the water. You need to rent a raft. There's plenty of good info about rafts online. Ditching in the North Atlantic is very survivable. Much more survivable, I think, than having an engine out over rocky, foresty, northern Canada.
You should stop in Ilulissat on the way over. It's amazing. Take a midnight boat ride on the ice fjord around all of the ice bergs that have calved off the Greenland ice cap. I spent one night in Ilulissat and one night in Kulusuk. Take advantage of the fact that you have a fun way to visit Greenland, which is very challenging for airline passengers to visit.
Be careful flying over the ice cap on a cloudy day, as you will have trouble figuring out how high you are over the ice cap, since the horizon disappears. I didn't appreciate this when planning my flight from Ilulissat to Kulusuk; I definitely appreciated it during my flight.
Reykjavik to Wick is your longest flight, and it's no problem in a plane like yours. You can bail out to the Faroe Islands, but other than that there are few options, so this trip is all about being smart about the weather and making good go/no-go decisions. Far North Aviation, the FBO at Wick, was really great; I don't know if the same guy is running it as the guy who was running it 20 years ago, though.
Greenland airports charge ridiculous fees if you land after they are supposedly closed. So watch out for that. I managed to avoid this mistake.
20 years ago, weather reports at least one place along this route (Iqaluit?) were delivered by fax. Maybe things have improved. But when I went across, it was good to know how to read the weather charts and to have confidence about knowing what to watch out for en route to confirm the forecast did not get it wrong.
Making position reports through airliners flying thousands of feet above you is fun. Those pilots are bored and happy to help and may be curious about your trip.
Learn the difference between Radar Advisory Service and Radar Information Service. Learn what QNH and QFE mean. Learn how to translate milibars to inches, or how to enter milibars into your kohlsman window. Fun: You get to fly in the flight levels, because other countries start the flight levels much lower than we do.
Learn the squawk codes for VFR flight. Hint: 1200 is for US and Canada but not for other places. ICAO uses 7000.
Connect with Mooney pilots at your destination. They are very friendly, and you know they're smart because they fly Mooneys.
I have flown to Alaska a couple of times, and to South America, and to multiple Caribbean countries, and to Mexico and Belize, and all over the US and Canada. All lots of fun, but it can't touch flying to Europe and back.
  • Like 12
Ovations can handle the trip nicely…
Find the threads where people have crossed the pond in their Mooneys…
One MSer does this ‘often’… from/to Boston…
@Gagarin posted pics of an ovation that he ferried across…
There is also a great detailed post of an MSer that took the southern route…
Study up on rafts, radios, and survival suits…
6 hours ago, Jerry 5TJ said:
The blog covers their round the world flight in a Piper Mirage. With the 4 aft seats removed to fit a ferry tank they had over 250 gallons aboard.
Yes, that’s the subject of this one, but he’s also well versed in trans Atlantic crossing in his former Mooney 252.  The current owner also hangs out here.
  • 1 month later...
Thank you for all the great info. We are planning to stop in the Faroe Islands.
If I remember correctly, there is a thread here on an N registered Mooney based in Germany that made the trip a couple of years ago.  They had made several round trips.  Oshkosh was one of their destinations.   Good luck, I am envious.
Have you checked on the price of insurance coverage.  In the past, several N registered aircraft were quoted a very high price just for the minimum EU coverage.  At least one owner scrubbed the flight due to cost of the required insurance, even when he excluded any hull coverage and only looked at the minimum liability required.
I have no idea what it costs now, and I do realize that Scotland isn't in the EU (but Iceland is).
Thank you. I will look into it, but it won't be a deal breaker for me.
Ha ha ha wow. I was reading this response and was thinking, huh, this really sounds like this member used ChatGPT to write this... Then I looked at user name "ChatGPT" :)
Yep. Blah blah blah, general summaries not relevant to your situation.
"Rent a raft from a local aviation supply company" doesn't give you a company name, website or even city to look for . . . Worthless!!
I almost had a gig ferrying about 5 AN-2 from Lithuania to US.  One of the pilots I recruited was a Brit with several crossings.
There is a company that will rent you rafts and suits and HF radios one way.  The service both ends of the trip, so you carry them Eastbound, someone else rents them and takes then Westbound, rinse and repeat.  IIRC the eastern end was Stornoway.
This is a bucket list trip for me.  My C doesn't have the legs for it, when I move into a 252 or a Bravo though, I'm going to get serious about planning it.  I hope your trip goes off smoothly, please share your progress in planning and pics/stories of the crossing.
Turtlepac for those trips where your plane doesn’t have the fuel legs that the trip requires…
also rentable, it sits on the back seat, or baggage compartment…
WnB is important as well…
I will
Names or websites?
There is a lot to HF radio installation and use. You can do a trailing antenna with a fishing downrigger reel on the pax floor, a hole in the floor and a plastic funnel backwards on the wire to out of the ice window I guess to the wingtip and then to the tail.
I’d just do an Iridium Sat phone myself, whole lot easier.
I did this back in the early 80s and did the trailing antenna thing which did not work out for me.  I used the ferry tank that was used in the original Meyers 200 around the world flight first single engine single pilot.  Still have that if you want to borrow it  52 gallons.
  • 4 weeks later...
I just returned to the US from a week long vacation in the Auchterarder, Gleneagles, St Andrews region of Scotland. I flew commercially so don’t have any advice for the trip in your Ovation.
I have been to Scotland several times before for work but never had time to see the country of Scotland. My work trips included spending the entire time inside of office buildings, hotels, and the Glasgow airport.
Scotland is beautiful, the weather last week was perfect, the Scottish people are really nice.
You will really enjoy your time in Scotland.
Let us all know how your trip was after you return.
Yep! N9303M
Two North Atlantic crossings - time to say goodbye - Vintage Mooneys (pre-J models) - Mooneyspace.com - A community for Mooney aircraft owners and enthusiasts
