Richie the C Posted February 28, 2023 Report Posted February 28, 2023 Our M20 J tach bounces all around, between 600 and 2400 rpm. Engine runs normally, I.e. sounds OK and no indication of surging. Anyone else had this problem? Quote
PT20J Posted February 28, 2023 Report Posted February 28, 2023 Mechanical or electric tach? If it’s mechanical you might try disconnecting the cable at the tach and pulling the core out and lubricating it with speedometer cable lube. Quote
Richie the C Posted February 28, 2023 Author Report Posted February 28, 2023 12 minutes ago, PT20J said: Mechanical or electric tach? If it’s mechanical you might try disconnecting the cable at the tach and pulling the core out and lubricating it with speedometer cable lube. Quote
Richie the C Posted February 28, 2023 Author Report Posted February 28, 2023 Thanks. How can you tell it mechanical? Quote
Fly Boomer Posted February 28, 2023 Report Posted February 28, 2023 1 minute ago, Richie the C said: Your response got lost in the Internet somewhere. Quote
Fly Boomer Posted February 28, 2023 Report Posted February 28, 2023 Just now, Richie the C said: Thanks. How can you tell it mechanical? Now I see it -- carry on. Quote
PT20J Posted February 28, 2023 Report Posted February 28, 2023 I believe all the mechanical tachs Mooney used were 3-1/8" diameter and have the recording hour meter built into the tach. I believe all the electric tachs were 2-1/4" diameter and have a separate recording hour meter. You can tell for sure by looking behind the panel and seeing if a speedometer cable comes out the rear of the tach. Quote
Richie the C Posted March 2, 2023 Author Report Posted March 2, 2023 It is mechanical. Thanks for the response. 1 Quote
N201MKTurbo Posted March 2, 2023 Report Posted March 2, 2023 I’ve seen that happen with Mitchell tachs. They are very sensitive to the tach cable pushing on the input bearing. This is caused by a cable that is worn out. The factory SW tach will run just fine with the warn out cable. I would suggest getting an electronic tach, your problems will go away. Quote
Richie the C Posted March 2, 2023 Author Report Posted March 2, 2023 Thank you. Good idea. Mr. Maxwell made the same suggestion. Quote
haymak3r Posted March 2, 2023 Report Posted March 2, 2023 I have a tach for sale too. from a 79 J Not sure how compatible they are. It is definitely mechanical. Quote
