Hi all,
I'm currently getting new insulation installed in my '78 J.  The shop doing it is concerned if they use the aluminum-backed insulation, they'll need to degauss afterward which in the past they've found to be time consuming.
Just wondered what experience others have with this?  Is degaussing typically part of the process when you carry out SB208?  Or do others use another type of insulation without aluminum?
Thanks,
Matt
It must be special aluminum if you can magnetize it. It’s also the wrong material to use.  Look up SBM20-208
"Intelligence has its limits ..  unfortunately Stupidity doesn't" Albert Einstein
Either they really are that stupid or they are trying to degauss your wallet
  • Haha 2
14 minutes ago, m100psi said:
Thanks all for the feedback. A MSC found the insulation kit associated with the SB…for $750.
If you are taking the entire interior out, you might consider replacing all the fiberglass with this foam. I bought it from OasisAero, the MSC in Willmar, MN that had a quantity of it in bulk. Even though Mooney replaced the side panels with foam, it continued to use fiberglass in the ceiling and baggage compartment. The foam is much better insulation for noise and temperature.
Putting in proper insulation can’t possibly require degaussing an airframe…
Unless the shop intends to bring the industrial vacuum cleaner into the cockpit to clean up after the work…
Large electric motors have been known to magnetize things nearby….  :)
If you have done compass turns… and there is a heading that the compass hangs on….rests a moment… then accelerates to catch up… this is a sign of a magnetized cage…
PP thoughts only, not a mechanic…
Only thing I’ve ever seen to magnetize a 4130 airframe is welding, and yes De-gaussing is a pain, but if you can access the tubes it’s not that bad. You use a big electromagnet and just move it around and use a little cheap needle gauge to verify the lack of magnetism. Gauss meter maybe?
Looked just like this https://www.bergeng.com/product/MF-2480.html?gclid=Cj0KCQiAi8KfBhCuARIsADp-A55fbOKEXnqbWdHNdqRx5nKdGaCdApBzqwcJuHlUk9SDbS4cKFzc5dUaArGPEALw_wcB
This meter and the fact the compass won’t swing will tell you if de-gaussing in needed, but without welding I’d be real suspicious.
We had to de-gauss maybe 1 in 10 aircraft we manufactured when I couldn’t get the compass to swing
