BDPetersen Posted January 4, 2023 Report Posted January 4, 2023 Thanks. Much appreciated. Is that for the 6 bladder system? Quote
takair Posted January 4, 2023 Report Posted January 4, 2023 3 hours ago, BDPetersen said: Thanks. Much appreciated. Is that for the 6 bladder system? Yes. Quote
Mooney Flyer Posted January 14, 2023 Report Posted January 14, 2023 Yes, it is easy. First, understand that gallons in the tank will not be linear. Start with empty tank and wooden 1/2" square 15" stick. Five gallons in tank. Mark at wetness point. Five more and so on. Now you have a stick with 5 gallon points, 30 min. On my stick on one side I have time, the other gallons. Mark the stick or another one which is going to be the one you carry. Give it three coats of good urethane varnish. Mine for a 63C has lasted 30+ years. Quote
Fly Boomer Posted January 14, 2023 Report Posted January 14, 2023 5 minutes ago, Mooney Flyer said: Yes, it is easy. First, understand that gallons in the tank will not be linear. Start with empty tank and wooden 1/2" square 15" stick. Five gallons in tank. Mark at wetness point. Five more and so on. Now you have a stick with 5 gallon points, 30 min. On my stick on one side I have time, the other gallons. Mark the stick or another one which is going to be the one you carry. Give it three coats of good urethane varnish. Mine for a 63C has lasted 30+ years. I have wondered how well the 100LL would "stick" to a painted or varnished surface. The guy who sticks the underground tanks at a local airport smears something on the stick to make the line more visible. Quote
Pinecone Posted January 14, 2023 Report Posted January 14, 2023 25 minutes ago, Fly Boomer said: I have wondered how well the 100LL would "stick" to a painted or varnished surface. The guy who sticks the underground tanks at a local airport smears something on the stick to make the line more visible. Are you sure that is what it is for? Normally, when you dip underground tanks, you put a smear of water indicating paste. It turns color when water touches it. Quote
Fly Boomer Posted January 14, 2023 Report Posted January 14, 2023 34 minutes ago, Pinecone said: Are you sure that is what it is for? Normally, when you dip underground tanks, you put a smear of water indicating paste. It turns color when water touches it. He applied it near the middle of the stick, not near the bottom where the water would be, and he told me it was to help identify the line between wet and dry. That said, maybe he was using it incorrectly. Quote
MikeOH Posted January 14, 2023 Report Posted January 14, 2023 I just use an untreated Home Depot paint stick with Sharpie markings. Five years in and the markings are still fine. Wet line is obvious on the wood but evaporates by the time I get to the other tank. 2 Quote
DonMuncy Posted January 15, 2023 Report Posted January 15, 2023 If you want to be fancy, you can cut grooves in your stick and fill them with JB Weld. Quote
Pinecone Posted January 16, 2023 Report Posted January 16, 2023 6 hours ago, DonMuncy said: If you want to be fancy, you can cut grooves in your stick and fill them with JB Weld. Using laser engraving, of course. Quote
