drifter001 Posted October 8, 2022 Report Posted October 8, 2022 (edited) Not sure if posting in the right place but does anyone have a how to on how to replace tail (white) nav light on a ‘65 M20E. Was looking in the AMM but didn’t see it there. It’s the regular non led one. TIA Edited October 8, 2022 by drifter001
Hank Posted October 8, 2022 Report Posted October 8, 2022 I thought it was just the two little screws that hold it in? Haven't looked closely at mine recently.
drifter001 Posted October 8, 2022 Author Report Posted October 8, 2022 4 minutes ago, Hank said: I thought it was just the two little screws that hold it in? Haven't looked closely at mine recently. I’d have to check again but don’t remember seeing any visible screws. There’s just the cover and if I remember correctly a chrome ish piece around the cover
Hank Posted October 8, 2022 Report Posted October 8, 2022 25 minutes ago, drifter001 said: I’d have to check again but don’t remember seeing any visible screws. There’s just the cover and if I remember correctly a chrome ish piece around the cover Seems the screws I remember go through the chrome trim, but I've never taken mine off to look under it.
drifter001 Posted October 8, 2022 Author Report Posted October 8, 2022 9 minutes ago, Hank said: Seems the screws I remember go through the chrome trim, but I've never taken mine off to look under it. I’ll have to double check when I get back home from work. My plane partner called me telling me it was burnt out
Hank Posted October 8, 2022 Report Posted October 8, 2022 Found a picture I took to clarify "long rudder vs short rudder." This closeup shows the two little screws that I remember. First thing I'd do is remove them, pull off the trim and see what else can be removed. Gently!
drifter001 Posted October 8, 2022 Author Report Posted October 8, 2022 Cool deal. Thanks for the pic references. Much appreciated
Fly Boomer Posted October 8, 2022 Report Posted October 8, 2022 12 hours ago, drifter001 said: I’d have to check again but don’t remember seeing any visible screws. There’s just the cover and if I remember correctly a chrome ish piece around the cover The lens is probably (expensive) glass. Caution advised. 1
