Caesar 15 Posted September 16, 2022 Report Posted September 16, 2022 My local mechanic fixed my loose nose gear….the steering was a little squirrelly on landing. He said two rod ends were worn out and rigged incorrectly. He charged me for 32 hrs of labor. What is a reasonable amount of labor to fix this problem? Also, he replaced the seal around the ram air intake door. What’s a reasonable cost and/or labor time to fix this? 7.2 hrs of labor seems excessive to me. Thanks for any input you can offer. -Brad Quote
Shadrach Posted September 17, 2022 Report Posted September 17, 2022 On 9/16/2022 at 7:46 PM, Caesar 15 said: My local mechanic fixed my loose nose gear….the steering was a little squirrelly on landing. He said two rod ends were worn out and rigged incorrectly. He charged me for 32 hrs of labor. What is a reasonable amount of labor to fix this problem? Also, he replaced the seal around the ram air intake door. What’s a reasonable cost and/or labor time to fix this? 7.2 hrs of labor seems excessive to me. Thanks for any input you can offer. -Brad I don’t want to second guess what someone else did without the whole story, maybe there is additional items you’re not understanding. The above being said, I should hope it did not take 4 full work days to replace a ram air gasket and two nose gear rod ends. Perhaps if you posted the bill it might reveal additional information. I’m pretty sure that I could replace all three gear legs with overhauled units in a single day and most aviation maintenance pros could work circles around me. Quote
N201MKTurbo Posted September 17, 2022 Report Posted September 17, 2022 I can remove a steering horn in about an hour. About the same to put it back in Removing the SS cover in the center of the firewall makes it much easier. Quote
Caesar 15 Posted September 18, 2022 Author Report Posted September 18, 2022 Thanks guys. This is what I was looking for. Quote
Joshua Blackh4t Posted September 18, 2022 Report Posted September 18, 2022 My mechanic did the ram air seal at the last annual and I didn't get an individual price, but he didn't mention it as difficult. Sounds excessive, but there might be more to the story. Quote
Jpravi8tor Posted September 18, 2022 Report Posted September 18, 2022 I have recently changed my ram air seal and could see where a maintenance shop owner would charge a minimum of 2 hours to change the seal. Quote
