haymak3r Posted September 12, 2022 Report Posted September 12, 2022 On 9/10/2022 at 7:18 PM, EricJ said: Got a pic of the "big round" antenna? It probably is an ADF antenna, if it's what I'm thinking, but a pic would clarify. The antenna in the link is a DME antenna if it's connected to your kns80. It may be useful as an ADS-B-in antenna if you don't have that already. I am pretty sure it is the ADF antenna. Which I should be able to safely remove. I'll keep the DME antenna for now since I am keeping the kns80 as a 2nd nav source. I have a gtx345 so don't think I would need the DME antenna for ADS-B. Thanks! 1
WAFI Posted September 12, 2022 Author Report Posted September 12, 2022 Thanks for the feedback, I removed it and also, cleaned up the transponder connection with electro cleaner. After removing all the other antennas on the belly, I feel like I'm going at least Mach 2 now. But there is one more in question--
EricJ Posted September 12, 2022 Report Posted September 12, 2022 18 minutes ago, WAFI said: Thanks for the feedback, I removed it and also, cleaned up the transponder connection with electro cleaner. After removing all the other antennas on the belly, I feel like I'm going at least Mach 2 now. But there is one more in question-- That could be transponder, DME, or ADS-B-in.
jamesm Posted September 12, 2022 Report Posted September 12, 2022 On 9/8/2022 at 10:23 PM, carusoam said: Next thing you will want…. A landing height system…. is this what you where eluding too https://landingheight.com/ 1
carusoam Posted September 13, 2022 Report Posted September 13, 2022 5 hours ago, jamesm said: is this what you where eluding too https://landingheight.com/ That is it! A few, or many, have been installed around here… @Microkit is a sponsor of MooneySummit… Find the thread of the continuous discussion around here… the MicroKit guy is always around supplying details and insight… best regards, -a-
