Yooper Rocketman Posted June 14, 2022 Report Posted June 14, 2022 My A&P and I removed the windshield last week. The new one arrived on Friday. It took us about 3 1/2 hours to remove it (I was lucky, original window with standard rivets, not cherry max), another 3 1/2 to clean all the old sealant out, and now ready to install. I'm ready to order the sealant and am wondering how many 6 oz. tubes it takes for the job? Anyone have some advice? I'm also ordering the power caulking gun for that size tubes. I've borrowed one before for installing TKS deice panels and it works so much easier than hand pumping with stage four arthritis in the wrists. Tom 1 Quote
Fly Boomer Posted June 15, 2022 Report Posted June 15, 2022 6 hours ago, Yooper Rocketman said: I'm also ordering the power caulking gun for that size tubes. I've been collecting supplies. I have the PRC, a bunch of nozzles, and the mixing device, but finally cancelled a manual caulking gun after a few months. Do you have a source for the power gun? Quote
Yooper Rocketman Posted June 15, 2022 Author Report Posted June 15, 2022 9 hours ago, Fly Boomer said: I've been collecting supplies. I have the PRC, a bunch of nozzles, and the mixing device, but finally cancelled a manual caulking gun after a few months. Do you have a source for the power gun? https://www.aircraftspruce.com/catalog/topages/sealantgun3.php Quote
jetdriven Posted June 15, 2022 Report Posted June 15, 2022 You can modify a Home Depot caulking gun by sanding down the diameter of the disk that fits inside the tube, and then you tape the PR 1422 SEM kit cartridge to the caulk gun and then give it hell. 1 1 Quote
Yooper Rocketman Posted June 16, 2022 Author Report Posted June 16, 2022 Still wondering how many tubes to seal a windshield? Would 4 be enough? Tom Quote
N201MKTurbo Posted June 16, 2022 Report Posted June 16, 2022 1 hour ago, Yooper Rocketman said: Still wondering how many tubes to seal a windshield? Would 4 be enough? Tom I would think one would be plenty. That stuff goes a long way. The surfaces fit flush so it doesn't take much. You can also get it in cans. Mix it up and thin it and apply with a brush. Quote
Yooper Rocketman Posted June 19, 2022 Author Report Posted June 19, 2022 On 6/16/2022 at 11:30 AM, N201MKTurbo said: I would think one would be plenty. That stuff goes a long way. The surfaces fit flush so it doesn't take much. You can also get it in cans. Mix it up and thin it and apply with a brush. The amount we peeled out was clearly more than one tubes worth. Maybe not 4 tubes though. Tom Quote
N201MKTurbo Posted June 19, 2022 Report Posted June 19, 2022 3 hours ago, Yooper Rocketman said: The amount we peeled out was clearly more than one tubes worth. Maye not 4 tubes though. Tom I will admit the only windshield I've done was in an M20F. It has screws all the way around. it fits very snug to the metal and requires very little sealant. the later models may not fit that snug and may require more. Quote
