Welp, I had my checkride on Friday, and passed with just a couple squawks. Overall I apparently did pretty well, though I felt like the sky was coming down around me haha. I am 32 hours in on my mooney, and did my checkride in it.
  • Like 14
Congrats! Enjoy your new-found freedom, and be careful.  These planes cover a lot of ground fast, so your instrument rating should be the next goal.
No doubt. It is a fun plane to fly! I am taking a couple weeks off, as the plane is now in for annual lol.. But then it is on to instrument training.
Woo-hooooo!! Congratulations!
Getting your PPL is an accomplishment! Finishing it in your own Mooney is exceptional!
Congratulations on a job well done ! Now go get some experience and begin dreaming about that flight with your passenger of choice.
Sounds like a job well done. Just so you know, instrument training can be a lot more difficult than primary.
yep. I've literally told my instructor, that I am both happy, and scared haha. Happy to be at the end of this part, but scared because now the real work begins :)
My advice to you, start hitting the books and get a leg up on the training before it even starts.
Congrats!
All the instrument rating requires is time, study, practice, and most importantly continuity. The more often you're able to fly with your instructor the easier it will be for you.
Good luck, keep us posted on your progress!
Cheers,
Rick
I would fly often, and learn power settings and how the plane reacts to any changes, including trim changes.
Then again, I was a VFR Mooney pilot for 3 years. But I KNEW my airplane and had no trouble flying with the panel covered up, hitting CFII-desired speeds and configurations.
Still, don't wait that long . . . .
Edited by Hank
Hank mentioned an important point - trim. You must learn to trim as quickly and accurately as possible. You won't be successful at instrument flying if you are constantly struggling to keep the plane flying straight and level.
highly recommend IFR6 for the instrument training if you're thinking accelerated training. I did it in my J last year and loved it.
  • 1 month later...
Congratulations, it sounds like you had a great experience. You may also want to check out Accelerated-IFR.com for continious training as they've trained dozens of M20 pilots, at their home base with student owned aircraft. They'll take you throuout the Mooney approved flight envelope to make you the master of your aircraft. When you call them you can ask them for references.
Also a flight simulator will become of more use than when you were getting your ppl. Just practicing entering a holding pattern and flying a full procedure chart will help with the timing and flow of procedures to accomplish to get your technique down and solidify what you learned in the aircraft by repetition. It’s better than just chair flying as it forces you to learn the timing of each event. 6 T’s Time Turn Throttles Twist Track Talk. Commit this to memory for each point and you will not forget nor get anything out of order. Good luck.
