Alan Maurer Posted January 12, 2022 Report Posted January 12, 2022 Hello Mooney Avionics People, I was told my #1 radio is scratchy and switched to #2 and told way better. I understand that servicing a G1000 is not that easy. Anyone have any idea of the possible causes of this. Mooney is a 2008 model Ovation. Thanks\ Alan N913ND
rbp Posted January 12, 2022 Report Posted January 12, 2022 in my plane, the #1 comm antenna is on the belly and #2 is on the top, so primarily I use #1 in the air and #2 on the ground to get the best reception. so maybe check where the antennae are?
buddy Posted January 13, 2022 Report Posted January 13, 2022 I’m having the same problem with mine only it’s my #2 and it’s transmit only otherwise comes in clear. Both of my antennas are on top and my #2 is aft but as far as I can tell it’s not an antenna problem. I called an avionics shop and they said they never heard of that problem and suggested I switch the 2 GIA’s around to see if it follows the problem. Well I tried that and as I thought you have to reload the software. My next stop is a good avionics shop, find out which box controls my #2 comm and send it to Garmin for repair.
Jeff_S Posted January 13, 2022 Report Posted January 13, 2022 According to photos online, both antennae are on top and this looks to be the same exact configuration as my G1000 Ovation. Swapping the GIA63Ws would be the obvious step, and would be a quick thing for an avionics shop to try. If the problem follows the radio then there's your answer. If it doesn't, then some more sleuthing is required, as it could be in the antenna, the wiring, etc. 1
LANCECASPER Posted January 14, 2022 Report Posted January 14, 2022 I’d be more likely to swap the antenna cables from 1 to 2 on the splitter which is on the avionics bay on the back. Especially if swapping #1 & #2 GPS requires any software re-load. That would either conform or eliminate the antenna as the culprit 1
atpdave Posted January 14, 2022 Report Posted January 14, 2022 46 minutes ago, LANCECASPER said: I’d be more likely to swap the antenna cables from 1 to 2 on the splitter which is on the avionics bay on the back. Especially if swapping #1 & #2 GPS requires any software re-load. That would either conform or eliminate the antenna as the culprit I think nav antennas are on a splitter, not com. 1
LANCECASPER Posted January 14, 2022 Report Posted January 14, 2022 1 hour ago, atpdave said: I think nav antennas are on a splitter, not com. I think you're right - then I'd just switch around the antenna cable connectors on the GIA-63's from 1 to 2 to see if you could isolate it
buddy Posted February 4, 2022 Report Posted February 4, 2022 Well I’m hoping the problem is solved. I brought the plane over to Daytona Aircraft Service and they swapped my #1 and #2 GIA-63W boxes around and with a little button pushing reprogrammed the G1000. I’ve taken a couple of flights since then and have had no com issues at all on both my #1 and #2 coms. Before I brought the plane over to the avionics shop I reracked the boxes myself to no avail so I’m not really sure why the problem went away. So for an hours labor it might be worth a try.
