SkepticalJohn Posted September 23, 2021 Report Posted September 23, 2021 I'm having an avionics shop upgrade the avionics/prop/autopilot/etc in my 1987 M20K 252/Rocket. All of the used parts are being listed on eBay by the avionics shop who's doing the upgrades. More items posted daily. You can buy through eBay or message me here on MS and I'll reply to them. Items listed below can be seen on eBay: https://ebay.com/usr/integrityaviationservices Garmin GNS 430W P/N: 011-01060-00 14/28 Volt (with cards, rack, connectors, and data loader) $6500 uAvionix skyBeacon Mod:3 P/N: UAV-1001856-002 (wingtip ads-b). $1700 Stock engine instrument cluster. Rochester Gauges Engine Instrument Cluster P/N: 640281-525 (Model: 6247-00319). $400 JPI EDM-700 P/N: EGT-701-6C (digital engine monitor). $700 KFC150 complete autopilot with alt preselect: KC 192 P/N: 065-0042-03 Flight Computer KFC 150. $2900 King KS 178 Primary Servo (Roll) P/N: 065-0051-02. $950 King KS 179 Trim Servo P/N: 065-0052-14. $950 King KS 177 Pitch Servo P/N: 065-0050-04. $750 KAS 297B Altitude/VS Selector P/N: 065-0065-01. $1400 King KI 256 Flight Command Indicator P/N: 060-0017-00. $500 King KA 51B Slaving Accessory P/N: 071-1242-06. $250 King KI 203 VOR/LOC/Converter Indicator P/N: 066-3034-00. $400 King KX 165 TSO P/N: 069-1025-25 VHF/NAV. $900 King KMT 112 Magnetic Azimuth Transmitter P/N: 071-1052-00 Flux Detector. $130 King KT 76A P/N: 066-1062-00 Transponder. $200 King KN 64 DME P/N: 066-1088-00. $550 King KG 102A Directional Gyro P/N: 060-0015-00. $350 King KEA 130A Encoding Altimeter P/N: 066-3064-05. $700 King KI 525A Nav Indicator P/N: 066-3046-07. $500 King KI 227 ADF Indicator P/N: 066-3063-01. $75 Stormscope: 3M Stormscope WX-10A Processor P/N: 78-8047-0985-1. $120 3M Stormscope WX-10A Display P/N: 78-8047-0984-4. $130 3M Stormscope Antenna P/N: 78-8041-7950. $100 SDI Hoskins Fuel GPH P/N: 205382-1 Model# FT101 Sys. P/N: 702165-1 (fuel flow). $180 Mitchell Mechanical Recording Tach P/N: D1-112-5225 (Model: 98480-225). $150 United Instruments Manifold Pressure Indicator P/N: 6411. $300 United Instruments Vertical Speed Indicator P/N: 7000. $200 GTP 59 OAT probe P/N: 011-00978-00. $450 Eventide Avionics Argus 5000-10-00 (Moving Map). $70 PS Engineering Audio Selector Panel P/N: PMA6000M. $600 Davtron M800 Chronometer (multi-function clock/da/oat/voltage indicator). $120 Electronics International TIT P/N: T-1P (digital TIT indicator). $150 U.M.A suction gauge 3-310-52. $180 Following soon will be: vacuum pump, standby vacuum, pneumatic speed brakes, 3 bladed prop, spinner, governor, and much more.
