This is from my 1990 MSE (28V electrical system), which had less than 2200 total hours at the time these parts were removed and seems to have been hangared most or all of its life. There are more parts to post, but this is a start. Everything worked great when removed. Connectors and trays are included where applicable.
I'll ship however you want from Raleigh NC; you just cover the actual shipping expense.
KI 525A HSI $600
PN 066-3046-00 SN 39245
KMT 112 Azimuth Transmitter $100
PN 071-1052-00 SN 36415
KA 51B Slaving Control $150
PN 071-1242-06 SN 14034
KG 102A DG $400
PN 060-0015 SN 31372
United 7000 Vertical Speed Indicator $100
PN 7000 SN 90167
United Altimeter $300
PN 5934PA-1 SN 1F529
KMA 24 audio panel $150
PN 066-1055-03 SN 30320
InterVOX AA80 Intercom $100
PN AA80-001 SN 4459
Aero Safe Guardian I backup vacuum system $900
B&D Hour Counter / Hobbs Meter $100 PN 880035-507
B&D EGT/OAT Gauge $200 PN 880001-507
B&D Tachometer Gauge $160 PN 880039-515
United Manifold Pressure Gauge $200 PN 880044
Suction Gauge, UMA $50
PN 3-310-55 SN A3914
MidContinent Clock MD-88L $75
PN 206918 SN 4778
1 hour ago, ZuluZulu said:
@mhrivnak is your panel retaining the turn coordinator?  Mine has somehow become fixed in place, as in, the little airplane does not move when I turn.
Almost everything came out in favor of a G3x Touch, but I already sold the turn coordinator.
Let’s get something better than a TC this time…
They we’re good back in the day… but an AI will be better…. With an inclinometer tube…
I already have two G5s, this is for a backup.
I’m on a mission to eliminate TCs… they wear and become less usable… without telling anyone…
When you go to use it in ordinary bumpy weather… is when you find out how unusable it really is…
So… consider getting a third AI instead….  :)
We lost a local Brand B because he had an AI failure… and descended into the clouds using the TC…. Came out the bottom in pieces…
How is that for a sales pitch?
Don't need to work too hard to convince me of an upgrade; the plane will eventually get a full G3X Touch panel (or whatever Garmin comes out with by then to replace that).  I'm only looking for a relatively cheap plug-and-play TC secondhand as a stopgap, but if anyone wants to sell me a cheap Lifesaver instead I won't complain. :D
