I'm a Luddite and just getting a tablet with Avare and iFly on it.
What or where can I find a mount to use it on the control wheel?
So many choices I have a headache   Who uses what? Proud member of the CB Club.
I have an 8"  ASUS Android tablet  Seems tom work fine laying in my lap or dropping to the floor all the time.
The RAM claw yoke grip is probably better for most than the other style.
In terms of cradle, I would avoid any of the form-fitting ones. Those tend to become obsolete with your very next tablet. The X-Grip and the Tab-Tite will both be a bit more flexible in the range of tablets and tablet cases they will accommodate. For example, I use both an iPad Mini and an 8" Samsung, and my Tab-Tite accommodates both, with case or without. Plus they are open in the back which I think helps with any overheating issues you may encounter.
I really like the design if the X-Grip but use a Tab-Tite. That's mostly because the X-Grip did not exist when I bought it. But the Tab-Tite has the extra advantage of being able to buy cups for it if you substantially change sizes. In my case, I originally used it with a full-size tablet; a cup purchase was all I needed to move down in size.
I use the setup Mark described above with an 8" Samsung tablet.
Ram yoke clamp (Not available on Amazon)
https://www.rammount.com/part/RAM-B-121BU
X-Grip Universal that Mark mentioned above, I did bend the arms on the sides that are gray in the picture so they stick out sideways, it keeps them from hitting the yoke and works better for me that way.
https://smile.amazon.com/gp/product/B006OQQ27E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Double Socket Arm (Medium)
Cliff - I have a whole box of RAM mounts that are collecting dust. Let me know the dimensions of the tablet you are using and I will see if I have a mount that I can send to you. I'll keep your membership solid in the CB Club.
