On 3/19/2021 at 1:48 PM, Hopsl said:
Does anyone have a part number and or know where to buy the seat adjustment bar for the passenger seat on an 87 M20J? Looks like someone stepped on ours, many times, and it's now keeping the pins from seating deep enough in the tracks.
thanks for any help
I'm having the same issue too. How does the bar prevent the pins from seating?
When the seat is full aft, the pins are riding on the top of the seat track. In that position, they hold the adjustment bar slightly elevated. Where the pins attach to the bar now becomes the fulcrum or pivot point for any down pressure on the front of that bar. If the bar is slightly bent around that fulcrum, the pins are held slightly high when seated in the tracks. Once the bar is repaired or replaced, a fix for this would be to drill holes in the track, at the full aft position, so the pins would be fully seated and the seat locked to the rear.
  • 1 month later...
Exactly what happened to my right hand seat, the bar was bent. I got it fix during the annual but was told that I need a new one. Has anybody responded to you on where to obtain one? My A&P tried the factory and Lasar, but no joy.
I believe that I have a new one in stock.  I’ll check tomorrow.
Were you able to check?
I have a new 140215-029.
  • 1 year later...
9 hours ago, mikey757 said:
Hello Doc, Do you still have this Bar, 140215-029, this is exactly what I need now. Thanks, Mike
He is not likely to accidently run across this post to a topic that was last active a year ago unless you do something to get his attention like this:  @M20Doc Mikey looking for a part.
I think I may still have one.  Email my wife tomorrow, maureen@tricityaero.com
I think I bought it from you soon after your original post.
