Electro Posted March 12, 2021 Report Posted March 12, 2021 I have an opportunity to buy a Comanche 250 which has not been flown or started in 10-12 years so the condition of the engine is a complete unknown. Other than boroscoping the cylinders, cleaning plugs and changing oil is there a recognized prepping procedure before trying to start the old girl?
carusoam Posted March 12, 2021 Report Posted March 12, 2021 Electro, Sounds like a great question for ComancheSpace... Wait just a second... I’ll post a link... @M20Doc If you know doc’s other plane... this is really funny... Best regards, -a-
Guest Posted March 12, 2021 Report Posted March 12, 2021 I would borescope the cylinder to see if they’re corroded, oil the cylinder walls with a fine mist through the spark plug holes, pre oil the engine with a pressure pot connected to the front right oil gallery. If you can’t get a pressure pot, you could build one out of a weed sprayer, some hose and fittings. On second thought maybe you shouldn’t do it. Once you work on and fly this Comanche you’ll never be the same and may want to sell your Mooney! Clarence
Electro Posted March 13, 2021 Author Report Posted March 13, 2021 Thanks for the oiling tip, Clarence. I'll see if I can put something together. Shh, the Mooney doesn't know about this yet.
carusoam Posted March 14, 2021 Report Posted March 14, 2021 Bring flowers and a bottle of wine with the pre-oiler... see if she notices... -a-
A64Pilot Posted March 27, 2021 Report Posted March 27, 2021 (edited) it’s the cam of course that will be your biggest concern. I’d pull a couple of cylinders one from each side and get a look. That also lets you get a good look at the cylinders too. Someone in my neighborhood is resurrecting a twin Comanche that hasn’t run in 15 or so years, they had rusted cylinders on the left engine but said the cam was good. I think they will know for sure in 50 hours, or so. I would inspect the filter in 5 hours, then 15, and finally 50, after 50 I’d start to feel lucky. ‘The moment you find metal that will stick to a magnet, stop and find out where it’s coming from, if you catch it in time you may save a crank etc. Put lots of oil in the cylinders and leaving the bottom plugs out spin it over several times with the starter to blowout all oil out before you put the plugs back in prior to starting. Last edit. Good luck on getting the plug out of the case, sometimes they can be a real bear to get out, you can pre-oil from just about anywhere even remove the pressure sender and go in there if you can’t get the plug out Edited March 27, 2021 by A64Pilot
Electro Posted April 1, 2021 Author Report Posted April 1, 2021 On 3/27/2021 at 10:28 AM, A64Pilot said: it’s the cam of course that will be your biggest concern. I’d pull a couple of cylinders one from each side and get a look. That also lets you get a good look at the cylinders too. Someone in my neighborhood is resurrecting a twin Comanche that hasn’t run in 15 or so years, they had rusted cylinders on the left engine but said the cam was good. I think they will know for sure in 50 hours, or so. I would inspect the filter in 5 hours, then 15, and finally 50, after 50 I’d start to feel lucky. ‘The moment you find metal that will stick to a magnet, stop and find out where it’s coming from, if you catch it in time you may save a crank etc. Put lots of oil in the cylinders and leaving the bottom plugs out spin it over several times with the starter to blowout all oil out before you put the plugs back in prior to starting. Last edit. Good luck on getting the plug out of the case, sometimes they can be a real bear to get out, you can pre-oil from just about anywhere even remove the pressure sender and go in there if you can’t get the plug out Pulling a couple cylinders may be cheap insurance. Thanks.
