Jhj123 Posted February 17, 2021 Report Share Posted February 17, 2021 The joys of aircraft ownership. It was a pretty gusty morning at KSMO. I thought I had closed the door while i was doing my pre-flight, but apparently not. A gust of wind blew the door open. The door is slightly off now, I have to pull it down so it lines up. I was on my way to an A&P for a few squawks so added that to the list. There is a slight bend which he hope the sheet metal guy can take care off. Oh well....... I was going to add a strap to the bottom of the door so it doesn't go all the way to complete stop and put pressure on the hinge- once its repaired, which i hope isn't a major issues Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 18, 2021 Report Share Posted February 18, 2021 Everything can be repaired... Pics if you see anything damaged... Add this one to the pile.... doors are all the way open or all the way closed... Because there is nothing to prevent the odd things that can happen... Hope it is just an adjustment back to normal... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Jhj123 Posted February 18, 2021 Author Report Share Posted February 18, 2021 Plane is at the shop, it happened while I was on my way to the shop will update when I get the butchers bill! 1 Quote Link to comment Share on other sites More sharing options...
GeeBee Posted February 18, 2021 Report Share Posted February 18, 2021 9 hours ago, Jhj123 said: Plane is at the shop, it happened while I was on my way to the shop will update when I get the butchers bill! You must be a Patrick O'Brian reader. Quote Link to comment Share on other sites More sharing options...
Jhj123 Posted February 18, 2021 Author Report Share Posted February 18, 2021 1 hour ago, GeeBee said: You must be a Patrick O'Brian reader. Ha! Oddly enough, that is true. I didn't even realize the use of the phrase until you pointed it out. I am a fan of (theoretical) nautical adventures but flying is my real love! Quote Link to comment Share on other sites More sharing options...
GeeBee Posted February 18, 2021 Report Share Posted February 18, 2021 Sometime we will have to meet over the scuttlebutt and compare tomes after the yellow flag has been hauled down in your port! Quote Link to comment Share on other sites More sharing options...
