Shadrach Posted October 26, 2011 Report Posted October 26, 2011 Greetings Ladies and Gents, I have finally become relatively comfortable with my BK AV8OR and its shortcomings. However, I am noticing that the suction cup windscreen mount gives up when climbing through DAs around 11,500ft. One would think that simply reattaching it at the higher DA would cement it in place...but so far this is not the case. Does anyone have any tricks or tips to solve or minimize this issue?
AndyFromCB Posted October 26, 2011 Report Posted October 26, 2011 Quote: Shadrach Greetings Ladies and Gents, I have finally become relatively comfortable with my BK AV8OR and its shortcomings. However, I am noticing that the suction cup windscreen mount gives up climbing through DAs around 11,500ft. One would think that simply reattaching it at the lower DA would cement it in place...but so far this is not the case. Does anyone have any tricks or tips to solve or minimize this issue?
xftrplt Posted October 26, 2011 Report Posted October 26, 2011 Quote: Shadrach ...climbing through DAs around 11,500ft. One would think that simply reattaching it at the higher DA would cement it in place...but so far this is not the case.
Shadrach Posted October 26, 2011 Author Report Posted October 26, 2011 Quote: xftrplt ...and one would be wrong. It's air pressure that presses the suction cup to the surface. At 11,500', you've got less than 70% of SL pressure. A larger cup may help by giving more surface area to counter the lower force per square inch.
xftrplt Posted October 26, 2011 Report Posted October 26, 2011 Quote: Shadrach ...and one would be wrong. It's air pressure that presses the suction cup to the surface. At 11,500', you've got less than 70% of SL pressure. A larger cup may help by giving more surface area to counter the lower force per square inch.
Shadrach Posted October 26, 2011 Author Report Posted October 26, 2011 Quote: xftrplt Respectfully, I'm not sure you do. There can be absolutely no air inside the cup, and it will still have <70% of the available adhesion at FL115 than at SL. Air density has absolutely nothing to due with it; it's purely a function of ambient air pressure.
carusoam Posted October 26, 2011 Report Posted October 26, 2011 Ross, I am with Dick on this one. Pressure differential is key here. Even though some "unusable" area is created by your expanding bubble, the "usable" area of your rubber suction cup has a lessened effect because nothing (or much less) is pressing to get in... Or else re-setting the suction cup at altitude should work, right? I could be wrong, keep bringing valid arguments, I may switch sides. Otherwise go with the super Velcro. Cessna pilots don't seem to have this problem....? Best regards, -a-
sleepingsquirrel Posted October 26, 2011 Report Posted October 26, 2011 I think that air pressure is what holds the thing to a surface, 90% . 10 % is the gecko lizard adhesion effect.
xftrplt Posted October 26, 2011 Report Posted October 26, 2011 If you've taken offense, I meant none but was addressing your OP, below: "One would think that simply reattaching it at the higher DA would cement it in place...but so far this is not the case." That's my point. At altitude, you can push the cup again to expel the air that has expanded, but it still won't support the weight because of the lower ambient absolute pressure. That's why I suggested a larger vacuum cup. I hope I've made myself (or at least the physics) clear. If not, I apologize a priori.
xftrplt Posted October 26, 2011 Report Posted October 26, 2011 What the hell. The Squirrel is right...or maybe it's just FM.
carusoam Posted October 26, 2011 Report Posted October 26, 2011 So far I'm still with Dick, but squirrel does bring sticky saliva juice to the front... -a- It seems my Garmin portable's antenna would not stay attached to the windshield either.... Apparently we are not supposed to fly above 5,000' according to the portables manufacurers...
orangemtl Posted October 26, 2011 Report Posted October 26, 2011 I suggest nails. They are indifferent to ambient air pressure.
Piloto Posted October 26, 2011 Report Posted October 26, 2011 Dick is very right on his explanation about air pressure holding the suction cup in place. Velcro on the other hand does not rely on ambient pressure but on mechanical linkage. The only weak link on Velcro is the adhesive itself. With time and heat it has a tendency to come off. Jos
xftrplt Posted October 26, 2011 Report Posted October 26, 2011 PS: Yes, I'm well aware of the effects of altitude on sealed containers, having been on numerous chamber rides, carried water bottles in my G-suit for years, and opened sealed crew meals for another twenty.
jetdriven Posted October 27, 2011 Report Posted October 27, 2011 Yep, you got it right Dick. I don't open the yogurt in the crew meals at altitude after a few instances.
Shadrach Posted October 27, 2011 Author Report Posted October 27, 2011 Quote: jetdriven Yep, you got it right Dick. I don't open the yogurt in the crew meals at altitude after a few instances.
Hank Posted October 27, 2011 Report Posted October 27, 2011 Quote: jetdriven Yep, you got it right Dick. I don't open the yogurt in the crew meals at altitude after a few instances.
xftrplt Posted October 27, 2011 Report Posted October 27, 2011 Ross, For sure, the horse is dead. And, at the risk of admittedly hijacking this (dead) thread, I have a question: Flying in to HGR from the west, I've noticed, about 10m to the west, what appears to be a SAM site (I've made a few lowish passes) embedded in the top of the mountain. My RHAW didn't light up, so I snapped some pics. Do the locals at HGR know about this? There are no restrictions around it. (I've seen another similar site near Charlottesville. Any info?
N601RX Posted October 27, 2011 Report Posted October 27, 2011 Here are some larger suction cups. You can get them from www.mcmaster.com. Rubber Suction Cups With Male Thread Great as nonslip feet for office machines and other items. All have a molded-in machine screw with male threads (except for 53535A33, which has an untapped hole). All suction cups are made of black rubber (except for 53535A45, which is gray). Maximum temperature is 200° F. Warning! Never exceed capacities. Never use to lift people or items over people. CupDia. LoadCap., lbs. (A) ScrewSize ( Pkg.Qty. PerPkg. 1" 2.5 5/16" 8-32 1/4" 10 53535A11 $6.81 1" 2.5 5/16" 8-32 3/8" 10 53535A22 7.66 1 1/4" 3 1 1/8" 9/32" __ 10 53535A33 6.76 1 3/8" 3 1/2" 8-32 1/4" 10 53535A12 7.24 1 3/8" 3 1/2" 8-32 3/8" 10 53535A25 9.47 1 1/2" 3.5 5/8" 8-32 3/8" 12 53535A23 12.63 3 1/8" 30 1 17/32" 1/4"-20 3/8" 4 53535A45 9.32 3 3/4" 50 1 3/8" 5/16"-18 5/8" 1 53535A46 5.16
Shadrach Posted October 27, 2011 Author Report Posted October 27, 2011 Quote: xftrplt Ross, For sure, the horse is dead. And, at the risk of admittedly hijacking this (dead) thread, I have a question: Flying in to HGR from the west, I've noticed, about 10m to the west, what appears to be a SAM site (I've made a few lowish passes) embedded in the top of the mountain. My RHAW didn't light up, so I snapped some pics. Do the locals at HGR know about this? There are no restrictions around it. (I've seen another similar site near Charlottesville. Any info?
