Let me clear, the actual unit still worked using the buttons, but the touch function would not work. This issue started about 3 months after installation. It would work on the ground, about 1hour in the air, then freeze. On a couple of occasions it rebooted, but still would not work properly. Just had the unit replaced today, about 10 minutes after takeoff it froze. The shop was closing so we headed home. It never recovered.
Any ideas?
  • Sad 1
great report Thomas...
For big G device issues...
The guy on the internet to contact is Trek Lawler...
Often found at BT...
He only has so much skill to be everywhere at one time....  @TrekLawler
unfortunately, he picked there... not his fault... so try not to hold it against him...   :)
It is a serious issue, so find their 1 800 if so inclined...
Is there such a thing? My experience is that Garmin tech support will only talk to Garmin authorized avionics shops.
They have sooo many rules... Trying to send an email to Trek has been a challenge...
I’ve spoken with tech support, there definitely is a number to call.  However, I’m sure it will be your installer who actually needs to fix the issue.  I’m no avionics tech, but with it happening again on a new unit could it be something else in your plane that’s interfacing with it?
Trek and a couple other Garmin techs browse there.  One handle called Garmin Support is used by at least two of them that I know. Trek answers under his own name. He is a supervisor.
Haven’t had the opportunity to speak with anyone this holiday weekend. An electrical engineer friend of mine said that it is probably a grounding issue. He proceeded to tell me how touch screens work, and lost me right after “the way they work is....”. Tomorrow is another day.
If you call their support number there is an option now for "Non-Dealer Support", I believe it is "Option 5", no joking.
Edited by Baker Avionics
Added info
