hammdo Posted January 10, 2020 Report Posted January 10, 2020 Wanted to see if anyone had one of each (worn out is fine). Want to see if my friend can machine these out of 7075 high grade aviation aluminum. PM me if I can borrow these long enough to have him see if it’s possible... -Don
Raptor05121 Posted January 10, 2020 Report Posted January 10, 2020 If your friend manages to make them, I would love to order some!
Sabremech Posted January 10, 2020 Report Posted January 10, 2020 I have a fairly new set of uplock and down lock blocks from LASAR in my bird. I’m not quite sure that I’d want to send them out, but would be willing to see what my shop would charge to make a set. David 3
hammdo Posted January 10, 2020 Author Report Posted January 10, 2020 (edited) I’d be good with that too. My friend made pulleys for my supercharger and does a lot of CNC work. 7075 is the strongest aluminum, I believe, available and would make a strong set of blocks! -Don Edited January 10, 2020 by hammdo
rbridges Posted January 10, 2020 Report Posted January 10, 2020 50 minutes ago, Sabremech said: I have a fairly new set of uplock and down lock blocks from LASAR in my bird. I’m not quite sure that I’d want to send them out, but would be willing to see what my shop would charge to make a set. David awesome, David!
Sabremech Posted January 11, 2020 Report Posted January 11, 2020 23 hours ago, hammdo said: I’d be good with that too. My friend made pulleys for my supercharger and does a lot of CNC work. 7075 is the strongest aluminum, I believe, available and would make a strong set of blocks! -Don There’s a couple of options that I’ll put out there. I can take my parts to my shop and have a drawing made which will give your shop the dimensions they need to make them. Your shop would need to program them into the CNC. Think this option would cost the least. Or, I can have them drawn and then made by my shop. Thanks, David
hammdo Posted January 11, 2020 Author Report Posted January 11, 2020 (edited) Price it with your shop making them would be a great start. I would assume multiple folks would like to get in on a batch run... Edited January 11, 2020 by hammdo
tigers2007 Posted January 11, 2020 Report Posted January 11, 2020 Buy a new one, copy it, and sell it here when your project is completed. Sent from my iPhone using Tapatalk
Sabremech Posted January 12, 2020 Report Posted January 12, 2020 1 hour ago, tigers2007 said: Buy a new one, copy it, and sell it here when your project is completed. Sent from my iPhone using Tapatalk As long as the purchaser complies with one part of the owner produced rules, such as supplying the aluminum.
M20F-1968 Posted January 12, 2020 Report Posted January 12, 2020 9 hours ago, Sabremech said: As long as the purchaser complies with one part of the owner produced rules, such as supplying the aluminum. I might be interested in one for the shelf (I replaced mine 400 hours ago). Any idea what grade of aluminum is used and is it hardened? John Breda
rbridges Posted January 12, 2020 Report Posted January 12, 2020 I didn't realize this was hard to find. I'd also be interested.
67 m20F chump Posted January 12, 2020 Report Posted January 12, 2020 I would like one for the shelf too.
Raptor05121 Posted January 12, 2020 Report Posted January 12, 2020 I don't have any local CNC shops. I would prefer to buy them made
cliffy Posted January 12, 2020 Report Posted January 12, 2020 Do we need to go through OPP and PMAs again? :-) :-)
1967 427 Posted January 12, 2020 Report Posted January 12, 2020 If someone was able to make a complete paper drawing, I am sure that someone else on Mooney Space would be able to generate a Solid Model of the part in either Solidworks or Pro”E”. With the solid model file in hand, the cost from a CNC would be reduced. This file (wouldn’t be viewable without the software), but can be easily shared and downloaded from a shared file on Mooney Space. In 2020 the tolerances off of a part created on a CNC 5-axis milling machine is much tighter than most parts manufactured in 1966.
hammdo Posted January 12, 2020 Author Report Posted January 12, 2020 David did say he’d consider that. -Don
Sabremech Posted January 12, 2020 Report Posted January 12, 2020 35 minutes ago, cliffy said: Do we need to go through OPP and PMAs again? :-) :-) No, I think we have this handled. 1
cliffy Posted January 12, 2020 Report Posted January 12, 2020 Just a thought Has anyone tried a repair by sleeving the hole and welding the slot? 1
hammdo Posted January 12, 2020 Author Report Posted January 12, 2020 (edited) Yes, I was going to check with my friend about doing that after I get a new set. I’d rather try and get a 7075 aluminum block machined myself. I think @Sabremech has a good handle on this and since they’d be ‘owner produced’, it could help everyone who may need a set. We could probably setup a prebuy once we have an idea of approximate cost. In fairness to David, he is in business and this has to be profitable for him (having my own business, working for ‘free’ can get costly). I think once the initial prebuy block set is paid, David could get the dimensions out for those to do their own while still having the ability to do more prebuy groups for those who would want to go that route. -Don Edited January 12, 2020 by hammdo
1967 427 Posted January 12, 2020 Report Posted January 12, 2020 McMaster Carr is a bit more expensive, but you can buy very close to the exact size you want to purchase, not a 6 foot long bar https://www.mcmaster.com/9055k32-9055K325 don’t know the exact dimensions but you might be able to get an up and down lock out of this one piece
hammdo Posted January 12, 2020 Author Report Posted January 12, 2020 Yeah, that's not bad at all. I get a lot from them... -Don
