xavierde Posted July 26, 2019 Report Posted July 26, 2019 So I've eventually found the right K and it's a 252. She's going for a pre-buy over the next few days and the only thing I'm trying to get my head around is the fully loaded cost of an overhaul. I should be able to get 300/400h on this engine before having to do that but I've had Mooney owner friends having to do it before 1500h :/ I am getting quotes from a few shops recommended on other MS threads but would be curious to hear about actual fully loaded cost of an overhaul or factory reman for this engine. Really excited to get my hands on this aircraft!!
gsxrpilot Posted July 26, 2019 Report Posted July 26, 2019 There really isn't any way to answer this question. It can range from probably $25K for an overhaul from Jewell or your local A&P to $85K for a factory reman after removal, reinstallation, new hoses, etc. There are just so many variables to consider. And much of it depends on what is found when your engine is opened up. For example can the case be reused, or taken on exchange? And even to what state are you paying labor/tax rates. Just budget $100K and you'll be fine :-) 4
xavierde Posted July 26, 2019 Author Report Posted July 26, 2019 Thank you for the range, it's exactly what I needed!
gsxrpilot Posted July 26, 2019 Report Posted July 26, 2019 I have almost 1600 hours on my TSIO-360. I'm planning on using Jewell Aviation http://www.jewellaviation.com/default.htm for the overhaul when my time comes. I would suggest giving them a call and getting their estimate. They publish their prices on the website, but giving them a call might be good.
exM20K Posted July 26, 2019 Report Posted July 26, 2019 also... be sure the quotes are apples:apples, especially with respect to accessories and turbo's/exhaust. Dunno about the TSIO360MB, but for the TSIO550G, the invoice includes new turbos and accessories, and it generally is priced very close to field overhaul when all that is taken into account. -dan 3
MIm20c Posted July 26, 2019 Report Posted July 26, 2019 New cylinders, overhauled fuel system, new or reman mags, overhauled exhaust, overhauled turbo/wg, new hoses, engine mounts, baffles, etc. I’d budget at least 40-45 and be prepared to reach deeper into the pockets while you’re in there. The engine overhaul process is no different from maintenance in general. Many decisions to make along the way. Make sure as you’re looking at used planes that the previous overhaul replaced/overhauled the required systems to even be considered one. (a number of them don’t...). 3
Geoff Posted July 27, 2019 Report Posted July 27, 2019 FWIW I had my TSIO 360 LB overhauled at Jewel about 100 hours ago and have been very pleased. Sent from my iPhone using Tapatalk 2
MIm20c Posted July 27, 2019 Report Posted July 27, 2019 15 minutes ago, Geoff said: FWIW I had my TSIO 360 LB overhauled at Jewel about 100 hours ago and have been very pleased. This will be a very important data point. Could you please share the approximate cost and items replaced/overhauled. 1
Geoff Posted July 27, 2019 Report Posted July 27, 2019 New items: pistons, gaskets, all hoses FWF, gaskets, etc Overhauled items: crank, case, turbo, Merlin controller, exhaust, fuel system, mags Reused items: alternator, vacuum pump, other small accessories Don Maxwell did the R&R. All of the above plus shipping and taxes ~$60K 2
MIm20c Posted July 27, 2019 Report Posted July 27, 2019 (edited) Cylinders, overhaul or new? This falls in line with the engine overhaul work we had done. The overhaul portion was about half of the complete out the door cost. I had to add it up a few time as I was amazed how the “small things” really started to become real dollars. Thanks again for providing that info! Edited July 27, 2019 by MIm20c
81X Posted July 27, 2019 Report Posted July 27, 2019 17 minutes ago, Geoff said: New items: pistons, gaskets, all hoses FWF, gaskets, etc Overhauled items: crank, case, turbo, Merlin controller, exhaust, fuel system, mags Reused items: alternator, vacuum pump, other small accessories Don Maxwell did the R&R. All of the above plus shipping and taxes ~$60K Factory new or OH cylinders?
kortopates Posted July 27, 2019 Report Posted July 27, 2019 (edited) On 7/27/2019 at 6:29 AM, 81X said: Factory new or OH cylinders? New pistons, which are required, means overhauled cylinders. An MB will be a few thousand more with the hydraulic controller and wastegate. Additional accessories add up too. Sent from my iPhone using Tapatalk Edited July 29, 2019 by kortopates
81X Posted July 27, 2019 Report Posted July 27, 2019 13 minutes ago, kortopates said: New pistons, which are required, means overhauled cylinders. An MB will be a few thousand more with more the hydraulic controller and waste gate. Additional accessories add up too. Sent from my iPhone using Tapatalk I'm not following. Aren't the options new or overhauled cylinders with new pistons during a major? Just curious which option made up the $60K.
kortopates Posted July 27, 2019 Report Posted July 27, 2019 I'm not following. Aren't the options new or overhauled cylinders with new pistons during a major? Just curious which option made up the $60K. Saying "new pistons" above rather than new cylinders means they O/H his cylinders. The labor is included in their engine OH base price.Sent from my iPhone using Tapatalk
MIm20c Posted July 27, 2019 Report Posted July 27, 2019 29 minutes ago, kortopates said: Saying "new pistons" above rather than new cylinders means they O/H his cylinders. The labor is included in their engine OH base price Interesting. I figured overhauled cylinders meant the valves/guides were replaced and the cylinder was machined/honed along with new pistons etc. Just saying pistons I thought the other components were left alone.
81X Posted July 27, 2019 Report Posted July 27, 2019 41 minutes ago, kortopates said: Saying "new pistons" above rather than new cylinders means they O/H his cylinders. The labor is included in their engine OH base price. Sent from my iPhone using Tapatalk I guess so. It was just odd not being listed in the “overhauled items” list.
FloridaMan Posted July 28, 2019 Report Posted July 28, 2019 Contact shops and get estimates. Aero Engines of Winchester did mine on my m20f and you should include them in your runnings. Getting an overhaul estimate for your engine prior to purchase will show you how much you need in the bank.
M20F Posted July 28, 2019 Report Posted July 28, 2019 20 hours ago, 81X said: I'm not following. Aren't the options new or overhauled cylinders with new pistons during a major? Just curious which option made up the $60K. Lycoming and Continental both list what is required to major an engine. You merely need to make those absolute minimum changes. So a cam shaft as example almost to the point of failing but in tolerance, well that is good enough. You really need a good mechanic to guide you through the process because some $20k overhauls are great, some $60k overhauls are bad, and vice versa. Given infant mortality is also real in an overhaul be prepared to do it again 200-300hrs after you do it as well. Aircraft ownership is like the lottery some people have great luck through ownership. Others have terrible luck (e.g. overhaul engine, don’t write down serials, oops AD on part X, lets tear it apart to see if the AD applies). Then you seal the tanks and find irreparable corrosion. There is nothing better than owning a plane though there is also nothing worse (except maybe a helicopter).
xavierde Posted July 28, 2019 Author Report Posted July 28, 2019 4 hours ago, FloridaMan said: Contact shops and get estimates. Aero Engines of Winchester did mine on my m20f and you should include them in your runnings. Getting an overhaul estimate for your engine prior to purchase will show you how much you need in the bank. Will do. I have received a few already but will actually ask for factory reman quotes vs overhaul since these will be apples to apples.
CaptRJM Posted July 28, 2019 Report Posted July 28, 2019 (edited) I contacted Triad in Burlington, NC to get an estimate on my TSIO 360LB. When all is said and done expect around $55K with case, crank, etc that can be overhauled. Estimate includes new Continental cylinders, new exhaust system, overhauled fuel system, overhauled Merlyn and Turbo, overhauled alternator, new Slick Mags with harness, all the typical hoses removal and installation. Since I'm extremely happy with my nickel carbide cylinders I'm hopeful Continental will offer NiC3 when I overhaul. If not, I'll probably just have Triad send out the new cylinders to Aircraft Cylinders of America and have them plated. ACoA did my current cylinders. Edited July 28, 2019 by CaptRJM typo
tigers2007 Posted July 29, 2019 Report Posted July 29, 2019 OT I know but for 89.9 AMU’s they will install this certified engine completely. Experimentals only for now and it’s not certified yet Sent from my iPhone using Tapatalk
kortopates Posted July 29, 2019 Report Posted July 29, 2019 OT I know but for 89.9 AMU’s they will install this certified engine completely. Experimentals only for now and it’s not certified yet Sent from my iPhone using Tapatalk Looks like it will be a great option for a Skyhawk. Wish them well, but they've been working on this for 25 years and been saying it'll be certified since 2011. Now that they got an infusion of cash a few years ago maybe it will finally happen. But I am skeptical we'll see a higher horsepower version suitable for a K in my lifetime.Sent from my iPhone using Tapatalk
aviatoreb Posted July 29, 2019 Report Posted July 29, 2019 5 hours ago, kortopates said: Looks like it will be a great option for a Skyhawk. Wish them well, but they've been working on this for 25 years and been saying it'll be certified since 2011. Now that they got an infusion of cash a few years ago maybe it will finally happen. But I am skeptical we'll see a higher horsepower version suitable for a K in my lifetime. Sent from my iPhone using Tapatalk How about this? 320-450 hp. V8 diesel. https://eps.aero/the-eps-engine/ 2
CaptRJM Posted July 29, 2019 Report Posted July 29, 2019 Wonder what the wet weight is on the EPS engine? With all the accessories and coolant it can't be that light.
Aerodon Posted July 29, 2019 Report Posted July 29, 2019 Here's what Airpower show for a TSIO360SB New List Price: $101,547 You Pay: $81,547*Payment: $946/Mo.+ Add to Cart*Exchange Core Value: $19,000 Rebuilt List Price: $85,048 You Pay: $65,048*Payment: $755/Mo.+ Add to Cart*Exchange Core Value: $19,000
