Brittain is in the process of reorganization after the passing of the owner.  Used parts are about the only choice at the moment.
You're not going to find it. Talk to Alan Fox on here, he can help you out with a suitable work around.
  • 3 years later...
I have one new in a plastic bag, never used.  Email me if you need this part.
duckey123@hotmail.com
Don Cook
  • 6 months later...
  • 3 months later...
It is unlikely you will ever be able to buy one again. You will need to make your own. Using a motorcycle inner tube seems like a viable method.
There are plenty of rubber fabricators who have the capability to make them. It would just take someone to do the PMA process to get it done.
The demand and market for them is dwindling, so doing it would be an act of aviation passion more than profit. Sad to say.
1 hour ago, Dale Ingle said:
Does anyone know where to find a seal PN2007-3
Thanks in advance
Sending you a PM…
  • 10 months later...
Seems like this might be an Owner Produced Part using motorcycle inner tubes? Does anyone have more info, like what size inner tube to use or a template to share? I know I need at least one. I probably should redo them all if this is an option. Currently working on a restoration project.
Thanks!
