larryb Posted April 24, 2019 Report Posted April 24, 2019 Does anybody have any info on the pitot heat monitor circuit/module? In the wiring diagrams it is shown as "CM101A" and a part number of 800221-505. Mine may be bad and I am wondering if anybody else has had an issue with this module and has any schematics. The same part is used for prop deice current monitor. Thanks, Larry Quote
rgpilot Posted April 25, 2019 Report Posted April 25, 2019 Mine doesn't work and the shop said they didn't know where it was and what it would cost so, decided to do without since pitot heat and stall heat both work. The light doesn't come on. Quote
carusoam Posted April 26, 2019 Report Posted April 26, 2019 Seeing if @M20Doc knows where the sensor for the pitot heat monitor is hiding? ^^^^ Best regards, -a- Quote
Guest Posted April 26, 2019 Report Posted April 26, 2019 I’m not sure where to direct you. I looked through both manuals looking for a clue. Might be time for a call to tech support at Mooney. Clarence Quote
Awful_Charlie Posted April 26, 2019 Report Posted April 26, 2019 I don't know what you get on a K, but on a Bravo they are CSLA1GE eg https://lasar.com/electrical-instruments/current-sensor-micro-csla1ge A search for the datasheet gives datasheet.pdf Quote
