Joe Larussa Posted February 23, 2019 Report Posted February 23, 2019 I have bladders in my 201 that leak every now and then. Seems to be leaking in the right center compartment. Happens about once a year then goes away. Noticed it again today after the plane sitting for two weeks. Prior to that because of bad weather it sat for a month and no leak. Any ideas?
Sam Muncy Posted February 23, 2019 Report Posted February 23, 2019 Hi, I am brand new to this forum. I am having a pre buy on a 1995 Ovation as we speak. Speaking of fuel bladders: the Ovation had 1 of the fuel bladders repaired a few years ago. How common is having just one fuel bladder repaired/ resealed? Should this be a red flag? How costly is having the bladder repaired? I hope jumping on to this thread is appropriate. Similar topic? Sam
jetdriven Posted February 23, 2019 Report Posted February 23, 2019 No bladders on Ovations. However, small tank leaks and patch jobs are somewhat common.
Hank Posted February 23, 2019 Report Posted February 23, 2019 17 minutes ago, jetdriven said: No bladders on Ovations. However, small tank leaks and patch jobs are somewhat common. Unless an owner put them in whe the tanks leaked . . . . Note to the new: resealing tanks vs. installing bladders is almkst a religious war here, right behind LOP vs. ROP znd massive plugs vs. fine wires. I stripped and resealed my tanks, and fly nicely and troublefree ROP with massive plugs. 1 1
jetdriven Posted February 23, 2019 Report Posted February 23, 2019 M20K and later owners got nothing to worry about, WRT the bladders Vs. reseal argument. They also dont worry about who makes the best buggy whip or 4-barrel carburetor...
Marauder Posted February 24, 2019 Report Posted February 24, 2019 I have bladders in my 201 that leak every now and then. Seems to be leaking in the right center compartment. Happens about once a year then goes away. Noticed it again today after the plane sitting for two weeks. Prior to that because of bad weather it sat for a month and no leak. Any ideas? Joe - it might be the interconnects between the bladders. They are mechanical fittings and possibly could loosen up. I would have your mechanic look at those areas. If it were a bladder leak, I would expect the leak to be continuous with fuel in them. Sent from my iPhone using Tapatalk Pro 4
Bob_Belville Posted February 24, 2019 Report Posted February 24, 2019 The STC SA2277CE or SA2350CE for the O&N/Griggs bladders covers C,D, E, F, G, J. Only. Ks and long bodies are not included.
Joe Larussa Posted February 24, 2019 Author Report Posted February 24, 2019 4 hours ago, Marauder said: Joe - it might be the interconnects between the bladders. They are a mechanical fittings and possibly could loosen up. I would have your mechanic look at those areas. If it were a bladder leak, I would expect the leak to be continuous with fuel in them. Sent from my iPhone using Tapatalk Pro That’s what I’m thinking. Usually only happens when I fill up and it’s sits for a week or two.
bob865 Posted February 25, 2019 Report Posted February 25, 2019 On 2/23/2019 at 6:42 PM, Hank said: Unless an owner put them in whe the tanks leaked . . . . Note to the new: resealing tanks vs. installing bladders is almkst a religious war here, right behind LOP vs. ROP znd massive plugs vs. fine wires. I stripped and resealed my tanks, and fly nicely and troublefree ROP with massive plugs. You forgot the for and against touch and go's 1
TTaylor Posted February 25, 2019 Report Posted February 25, 2019 We just had to have our bladders worked on. There was some smell of fuel in the cockpit. Our mechanic found several of the fittings were loose, allowing fuel to leak. He tightened up the connections, hopefully that will fix the issue.
m20kmooney Posted February 25, 2019 Report Posted February 25, 2019 (edited) On 2/23/2019 at 5:11 PM, Joe Larussa said: bladders... leak every now and then Leaky bladder is a sign of Urinary Incontinence. It’s loss of bladder control, and ranges from a slight loss of urine after sneezing, coughing, or laughing to complete inability to control urination. It’s more common in women. Is your Mooney a boy or girl? Edited February 25, 2019 by m20kmooney 1 4
Joe Larussa Posted February 26, 2019 Author Report Posted February 26, 2019 8 hours ago, m20kmooney said: Leaky bladder is a sign of Urinary Incontinence. It’s loss of bladder control, and ranges from a slight loss of urine after sneezing, coughing, or laughing to complete inability to control urination. It’s more common in women. Is your Mooney a boy or girl? Ha! It’s all boy!
Mcstealth Posted February 26, 2019 Report Posted February 26, 2019 18 hours ago, m20kmooney said: Leaky bladder is a sign of Urinary Incontinence. It’s loss of bladder control, and ranges from a slight loss of urine after sneezing, coughing, or laughing to complete inability to control urination. It’s more common in women. Is your Mooney a boy or girl? You beat me to it.
Mcstealth Posted February 26, 2019 Report Posted February 26, 2019 On 2/23/2019 at 5:18 PM, Sam Muncy said: Hi, I am brand new to this forum. I am having a pre buy on a 1995 Ovation as we speak. Speaking of fuel bladders: the Ovation had 1 of the fuel bladders repaired a few years ago. How common is having just one fuel bladder repaired/ resealed? Should this be a red flag? How costly is having the bladder repaired? I hope jumping on to this thread is appropriate. Similar topic? Sam Welcome to the forum. Please post a hello on the main board and tell us about yourself.
Joe Larussa Posted April 26, 2019 Author Report Posted April 26, 2019 Problem solved! Opened up the center bladder and tightened the four clamps. Filled that sucker to the top and no leak! 3
moosebreath Posted April 26, 2019 Report Posted April 26, 2019 I had the same problem with the same solution. We finally double clamped the most troublesome interconnect tubes and that has been a long term fix.
RobertGary1 Posted April 26, 2019 Report Posted April 26, 2019 Can't be true. The bladder guys say they never leak
Marauder Posted April 26, 2019 Report Posted April 26, 2019 Can't be true. The bladder guys say they never leak Technically the bladders weren’t leaking. The interconnects were. Sent from my iPad using Tapatalk Pro
m20kmooney Posted April 26, 2019 Report Posted April 26, 2019 (edited) Breakthrough solution for leaky bladders! This powerful blend has been shown to decrease leaks by an incredible 79% and is backed by over 35 clinical studies! Best to use one capsule at each fueling. Save your Mooney the embarrassment that goes with loss of bladder control at the most inopportune moments! Use Bladder Brake! Special new formulation will not interfere with speed brakes! Edited April 26, 2019 by m20kmooney
BKlott Posted April 26, 2019 Report Posted April 26, 2019 I have one bladder that has been in service since 1957 but the Doc says no way we can replace it. 1
