eman1200 Posted July 19, 2018 Report Posted July 19, 2018 does anyone have the tail cone strobe part # that goes along with the 650's? thanks...... Quote
kortopates Posted July 19, 2018 Report Posted July 19, 2018 does anyone have the tail cone strobe part # that goes along with the 650's? thanks...... It's a Orion 500. Part no will depend on 12v vs 24 volt. Like the 650, it's a combination strobe and nav light. Sent from my iPhone using Tapatalk Quote
eman1200 Posted July 19, 2018 Report Posted July 19, 2018 Just now, kortopates said: It's a Orion 500. Part no will depend on 12v vs 24 volt. Like the 650, it's a combination strobe and nav light. Sent from my iPhone using Tapatalk ok I see the 500 on their website, thanks! Quote
kortopates Posted July 19, 2018 Report Posted July 19, 2018 I have the 650E’s installed and synched. I see no fluctuations anywhere. Nice, but not quite the same since yours has the tail strobe firing in-between your sync'd wing Orions. That could be evening out the draw - I don't know.Sent from my iPhone using Tapatalk 1 Quote
Marauder Posted July 19, 2018 Report Posted July 19, 2018 does anyone have the tail cone strobe part # that goes along with the 650's? thanks...... I have one. You will need to run one or two wires to it if you want the sync feature. The other wire is used to connect to the strobe switch and you would reuse the original Nav wire to turn on the solid white. Sent from my iPhone using Tapatalk Pro 3 Quote
powder_hounder Posted August 10, 2018 Report Posted August 10, 2018 On 5/1/2018 at 9:54 AM, Marauder said: If you can hold out until Oshkosh, you will find they will be running a show special. I can’t remember the exact discount but it was enough for me to reach into my Cheap Bast$#d wallet and retrieve my dust covered credit card and order them. No luck for me at Osh getting a deal on these, Spruce and the others wanted full price. Quote
jetdriven Posted August 10, 2018 Report Posted August 10, 2018 We got 18 or 20% off. 600s for 449 each and the tail nav strobe for 335 Quote
