EricJ Posted December 23, 2017 Report Posted December 23, 2017 I have a TT31 and like it a lot. The timer function is an easy way to track flight time. The reported altitude display is also nice since I fly under the Phx Class B frequently. Quote
Andy95W Posted December 23, 2017 Report Posted December 23, 2017 40 minutes ago, EricJ said: The reported altitude display is also nice since I fly under the Phx Class B frequently. I'm not sure if that is really all that helpful? The vertical limits of airspace is true altitude, but the "reported" altitude is pressure altitude (corrected to 29.92). ATC computers correct your reported altitude based on the local altimeter setting. Quote
carusoam Posted December 23, 2017 Report Posted December 23, 2017 Transponders... I'm in the run it to failure swap out with the used KT76C... nice push button display that doesn't interrupt your cognition process by turning knobs in reverse direction... Then upgrade to KT74 for ADSB out compliance over the next two years... See @Alan Fox for used transponders and things like this... Best regards, -a- Quote
TWinter Posted December 23, 2017 Report Posted December 23, 2017 Just had a tire replaced and had my GTN750 updated. My 750 was two updates behind. It took all of about 15 minutes to update. No charge (but they had done all my avionics prior so I'm sure they've made it back over the years). -Tom Quote
eman1200 Posted December 24, 2017 Report Posted December 24, 2017 Just had my 650 and 345 software updated, was charged 1 hr. Actual work was prob 15-20 minutes. Quote
bradp Posted December 24, 2017 Report Posted December 24, 2017 I had two iterations of software for the GNS and an update for the GDl-69 and the shop charges me a total of an hour. Logbook entries took longer than the software loads. They said they do updates for pretty much free if they have the cards and the installation was performed there. Quote
Oldguy Posted December 24, 2017 Report Posted December 24, 2017 On 12/23/2017 at 8:38 AM, LANCECASPER said: The Trig TT31, the King KT74 and the Avidyne AXP340 are all the same transponders made by Trig, just with difference faces on them.. I have the AXP340 version and am well satisfied. The King and Avidyne versions have direct enter number buttons which makes it a little easier. The face on the King probably looks the best in my opinion, although some people have mentioned that it is not bright enough if viewed at an angle. All three have the same functions - just different button pushes to get there. Trig King Avidyne I have the KT-74 and like it except for one minor detail. The STC does NOT apply to the Avidyne IFD series of navigators, so if I am going to swap my 430W for a 440, I will have to swap out the KT-74 as well. Quote
EricJ Posted December 24, 2017 Report Posted December 24, 2017 On 12/23/2017 at 10:42 AM, Andy95W said: I'm not sure if that is really all that helpful? The vertical limits of airspace is true altitude, but the "reported" altitude is pressure altitude (corrected to 29.92). ATC computers correct your reported altitude based on the local altimeter setting. Since there's always variation in what is the 'local altimeter setting', and especially what might actually be set in the Kollsman windows of a population of airplanes flying in a region, it's informative to me to see what the transponder is actually reporting. It goes back to the reason of why the transponder reports pressure altitude rather than what your altimeter is reporting to you on its display. Quote
flyboy0681 Posted December 24, 2017 Author Report Posted December 24, 2017 While I appreciate all of the replies, a lot of you are losing sight of one thing.. the plane is already ADS-B compliant and all I am looking for a very low cost transponder. A lot of the replies here point out state-of-the art units that cost thousands. My goal is to install a late model unit, which are now plentiful on the used market due to all of the ADS-B installs going on. Quote
LANCECASPER Posted December 24, 2017 Report Posted December 24, 2017 1 hour ago, flyboy0681 said: While I appreciate all of the replies, a lot of you are losing sight of one thing.. the plane is already ADS-B compliant and all I am looking for a very low cost transponder. A lot of the replies here point out state-of-the art units that cost thousands. My goal is to install a late model unit, which are now plentiful on the used market due to all of the ADS-B installs going on. Buy an adaptor that's compatible with the KT76 and slide in a Garmin GTX320. They are super cheap used and reliable. https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=garmin+gtx320&_sacat=0 Quote
