Rodeo John Posted November 19, 2017 Report Posted November 19, 2017 (edited) GooD day to all am trying to find a swivel joint for the mixture rod end part number 660051-3 for my 1966 M20 E ! Can anyone tell me where to get one and what the cross numbers for aircraft spruce might be ! Thanks to all you good People! Edited November 19, 2017 by Rodeo John Doubled
carusoam Posted November 19, 2017 Report Posted November 19, 2017 There is a lot in this thread that may be helpful... like macfarlane... But finding just that final detail may take more MS search skills than I have today... Best regards, -a-
Guest Posted November 20, 2017 Report Posted November 20, 2017 The ball and socket rod ends are obsolete and have been replaced with a rod end bearing, a bolt and spacer. Clarence
Rodeo John Posted November 20, 2017 Author Report Posted November 20, 2017 If the part is obsolete! What is the number of the rod end ? And would the one for the prop governor be the same ? That would be for future ! But would be nice to know !
Rodeo John Posted November 21, 2017 Author Report Posted November 21, 2017 The part number 660051-3 is no longer available! Kit from mooney 660051-005 to replace the obsolete part ! Getting kit from Don Maxwell . At least we have obtions! Thanks to all ! 1
carusoam Posted November 22, 2017 Report Posted November 22, 2017 Nice follow-up details, RJ. Best regards, -a-
cbarnes403 Posted November 23, 2017 Report Posted November 23, 2017 Found this one on eBay https://www.ebay.com/itm/NEW-SURPLUS-MOONEY-AIRCRAFT-660051-003-BALL-JOINT-ROD-END-/401285721272?vxp=mtr&hash=item5d6e7e2cb8
Browncbr1 Posted August 18, 2020 Report Posted August 18, 2020 On 11/19/2017 at 9:10 PM, M20Doc said: The ball and socket rod ends are obsolete and have been replaced with a rod end bearing, a bolt and spacer. Clarence Hi Clarence, Could you please help me with which rod end bearing, bolt and spacer is going on F models these days? I found this swivel type https://www.aircraftspruce.com/catalog/appages/swivelbearing.php?clickkey=4183 https://www.aircraftspruce.com/catalog/appages/hmbrng.php?clickkey=4183 https://www.aircraftspruce.com/catalog/appages/aurorabearfem.php?clickkey=4183 Thanks! Craig
Guest Posted August 18, 2020 Report Posted August 18, 2020 HF-3 rod end bearings are the most common. I looked through the Mooney kit list and could not find the kit number. A quick shout to LASAR should get you fixed up with the kit or individual part numbers. Clarence
