I have had intermittent mag problems for a couple months now.  Got to the point we could start the plane then the left mag would fail after a little while.  The mechanic thought coil or condensor.  It turned out that the bushing through the center of the distributor block was loose.
Why would that cause the mag to fail, especially only after it was warm?  I could see the coil or condensor failing after they got hot.
The reason for your intermittant mag problem is probably internal arcing on the distributor block. You didn't say what kind of mags you have but basically the center bushing being loose suggests that the insulating packing in there is bad and allowing the spark to jump to ground internally. Mags have to be pretty much perfect to do what they must.
