milotron Posted September 1, 2017 Report Posted September 1, 2017 hi, apologies is this has been discussed already, but searching didn't turn anything up. Anybody have on of these 3 blade MT composite props on a K ? Looking for performance or sound improvement feedback if anybody has first ( or second ) hand knowledge of this. It is an MTV-12-D evidently. iain
peevee Posted September 1, 2017 Report Posted September 1, 2017 3 blade is for wimps, go 4 blade like @aviatoreb I'd be concerned about that paint erosion if I were him, but I have heard only good things about the MT props. There's a K on field with one, sure looks nice. 2
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 4 blade is awesome, but likely far too much prop for my lowly TSIO360MB. I did notice that erosion of the finish also. iain
Smroot Posted September 1, 2017 Report Posted September 1, 2017 I have this prop on my Encore. It replaced a two blade Hartzell before I owned it so I can't personally compare the two. It is smooth and improves climb performance but I think it slows me down. I also have the paint peeling issue as in the photo.
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 Nice! What do you see for cruise speeds? iain
peevee Posted September 1, 2017 Report Posted September 1, 2017 2 minutes ago, Smroot said: I also have the paint peeling issue as in the photo. boy that would irritate me. It's pretty rare to see that on metal props.
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 My TKS knocks me down a bit already. That would likely put me 10kts under book speeds.
kortopates Posted September 1, 2017 Report Posted September 1, 2017 Great prop, but be aware it adds new challenges to R & R'ing the lower cowling. Erik could give you a first hand account since you'll be in the same predicament with 3 blades.Sent from my iPhone using Tapatalk 1
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 36 minutes ago, kortopates said: Great prop, but be aware it adds new challenges to R & R'ing the lower cowling. Erik could give you a first hand account since you'll be in the same predicament with 3 blades. Sent from my iPhone using Tapatalk Do you have this on your 252? iain
carusoam Posted September 1, 2017 Report Posted September 1, 2017 Expect some efficiency from the blade design, but the old blade design was pretty good... the large chord paddles probably show up as a negative on the ASI.... exposed surface area. improvements should be expected in getting off the ground and climb rate... The engine still needs to drive the excess aero-efficiency that is available... FF... Will your plane benefit from a much lighter prop? (Mine would) Is there a difference in blade length? Best regards, -a- 1
KSMooniac Posted September 1, 2017 Report Posted September 1, 2017 I know their prop that is approved for the J is a smaller diameter than any of the metal options. I expect the K version is as well.Sent from my LG-US996 using Tapatalk 1
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 Anybody have a sense of the cost of these?
aviatoreb Posted September 1, 2017 Report Posted September 1, 2017 I think they are supposed to have improved their paint process. But separately the nickel leading edge is a much deeper sheath and substantial than the original stainless steel edge. As for performance, while 4 is going to be slower than 3, all things being equal, I don't think my install slowed me down but sped me up "slightly". Why? My guess - The old mcauley 3 blade it replaced was an old school design aerodynamically competing against this modern scimtar shaped 4 blade. ALSO, not to be understated is the change of cg was significant rearward, as 35lbs came off the nose. It changes a nose heavy airplane to a more centered cg airplane - which also makes for nice benefits in the "road feel" when hand flying, it feels a lot lighter. And for sure climb improved a bit too. 2
aviatoreb Posted September 1, 2017 Report Posted September 1, 2017 49 minutes ago, milotron said: Anybody have a sense of the cost of these? Yes I know how much....- but I am embarrassed to say. :-O You know what they say, "if you gotta ask...." Cost is the big downside. Sound, cg, cruise speed, climb, road feel, looks, ground clearance, durability, sound, and a few more things, all better. Cost not so much.
milotron Posted September 1, 2017 Author Report Posted September 1, 2017 4 minutes ago, aviatoreb said: Yes I know how much....- but I am embarrassed to say. :-O You know what they say, "if you gotta ask...." Cost is the big downside. Sound, cg, cruise speed, climb, road feel, looks, ground clearance, durability, sound, and a few more things, all better. Cost not so much. I suspected as much ...but soo pretty! Did you come from a 2 or 3 blade? Rockets are all 3 I believe, correct?
peevee Posted September 1, 2017 Report Posted September 1, 2017 5 minutes ago, milotron said: I suspected as much ...but soo pretty! Did you come from a 2 or 3 blade? Rockets are all 3 I believe, correct? Correct. And a longer 3 blade than the stock k 2 blade, lol
DonMuncy Posted September 1, 2017 Report Posted September 1, 2017 3 blade MT. If my memory is working properly, I think about 14 AMU. I love mine. Very much quieter, smoother, lighter, better take off and climb performance, and better landing speed drag for slowing down. I can not discern any cruise speed decrease, but I admit I do not have any really good data to back that up. 2
aviatoreb Posted September 1, 2017 Report Posted September 1, 2017 1 hour ago, milotron said: I suspected as much ...but soo pretty! Did you come from a 2 or 3 blade? Rockets are all 3 I believe, correct? Thanks! And you know what they say, "its better to look good than to feel good ... and you look marvelous!" Rockets have 3 blades because you need a lot of blade surface area to suck up 305hp, and 2 blades therefore would be too long. Even the 3 blade is very long and you have a good bit less ground clearance than a standard M20k 2 blade. The 4 blade you get back the original m20k tsio360 ground clearacne and a tad bit more I think. 1
aviatoreb Posted September 1, 2017 Report Posted September 1, 2017 1 hour ago, DonMuncy said: 3 blade MT. If my memory is working properly, I think about 14 AMU. I love mine. Very much quieter, smoother, lighter, better take off and climb performance, and better landing speed drag for slowing down. I can not discern any cruise speed decrease, but I admit I do not have any really good data to back that up. Ok...ok I'll let on but don't think I'm silly ... promise. I can't remember exactly but I think STC and prop started at something like 17 or 18 with new prop governor too? But it was a bit more because I had to custom pay for a 337 field approval that they handled for me. Then I opted for the upcharge for the nickel treatment - which I think is very worthwhile to protect the investment. So all in...it was 21-22ish?
Guest Posted September 1, 2017 Report Posted September 1, 2017 I have a 3 blade MT on my 400 and am very happy with it, 38 pounds lighter than the Hartzell. It's hard to say if it's smoother with 8 cylinders. I have had no paint issues, I do wish I did the nickel leading edges. Clarence
kortopates Posted September 2, 2017 Report Posted September 2, 2017 Do you have this on your 252? iain No, not yet but considering it for when the day comes. But also concerned about the added challenges with the cowling. I like that I can do it by myself right now. Mooney changed the height of the lower cowling on the long body's to handle the 3 blade props.Sent from my iPhone using Tapatalk
DonMuncy Posted September 2, 2017 Report Posted September 2, 2017 I forgot to mention. The 3 blade prop makes it a little more difficult to remove the lower cowling, but not much. 1
kortopates Posted September 2, 2017 Report Posted September 2, 2017 Correct. And a longer 3 blade than the stock k 2 blade, lol Yes, and by about 2 inches if I recall right. No porpoising for you!Sent from my iPhone using Tapatalk
milotron Posted September 2, 2017 Author Report Posted September 2, 2017 11 minutes ago, kortopates said: No, not yet but considering it for when the day comes. But also concerned about the added challenges with the cowling. I like that I can do it by myself right now. Mooney changed the height of the lower cowling on the long body's to handle the 3 blade props. Sent from my iPhone using Tapatalk This is what I am thinking. If/when by 2 blade prop requires major work or replacement this will be the route to go. iain 1
