Good Morning,
I'm looking at putting shoulder harnesses in my 68 M20F. Does anyone have any info on install procedures or time?
        Thanks,
        Mike
Quote: mtrebbe
Good Morning,
        Thanks,
        Mike
I put mine in my 69F when the plane was apart for radios. I spent about an hour doing it. You will need to remove the window trims and the seats to do this. This would be additional time.
Ron
The hardest part is slipping the clamp between the skin and tubing.  My plane was very tight.  We did it while the windows were out which made it easier.  Some small wood wedges will help get the clamp in place.  Probably an hour for each side.  The Copilot side is easier to get the clamp around.
