Vref Posted December 17, 2010 Report Posted December 17, 2010 Can't seem to find a reference in the IPC on the seal that you see on many M20J's between the fuselage and the horizontal stabelizer..? There is a gap of a couple of mm and to my understanding you could use a snap on U profile from rubber or so Anybody knows what kind of material is beeing used here refrence P/N..? Silcone Rubber..etc.. thanks Luc Quote
Piloto Posted December 17, 2010 Report Posted December 17, 2010 Just go to Pep Boys and get the Door Edge Guard used in car doors. They are designed to whistand the outside environment and UV. José Quote
Vref Posted December 17, 2010 Author Report Posted December 17, 2010 Thanks José, Good tip, will look for an EU alternative for this kind of shop.. tnx Luc Quote
thinwing Posted December 17, 2010 Report Posted December 17, 2010 you could do that...but it is a standard aviation grade u channel availble through aircraft spruce (they have a european division in the uk I believe) and costs about a couple bucks a foot...this is a black neoprene material ,though the example in your picture has been painted...since your posted pics look like a job well done,why dont you stick with known avation venders??...my 2 cents..kpc Quote
thinwing Posted December 17, 2010 Report Posted December 17, 2010 oh I forgot to mention the door guard stuff is not as flexible and wont make that tight radius curve ...and it should be applied with 3m contact adhesive..kpc Quote
Vref Posted December 17, 2010 Author Report Posted December 17, 2010 Thanks for the comments. I will try to find aerospace quality. I am just surprised this is not mentioned in the service nor ipc manual...or I missed it totally btw the pic is of factory m20 mse luc Quote
thinwing Posted December 17, 2010 Report Posted December 17, 2010 I know...my 2000 m20m looks the same...paint right over the rubber u channel...by the way i have a roll of this stuff in my hanger...I bought it when I restored a Pitts s1s....your paint scheme on your project looks great!!!..kpc Quote
Mcstealth Posted December 18, 2010 Report Posted December 18, 2010 Quote: Piloto Just go to Pep Boys and get the Door Edge Guard used in car doors. They are designed to whistand the outside environment and UV. José Quote
piperpainter Posted December 18, 2010 Report Posted December 18, 2010 Lasar aircraft will have them! Perfect size too. Quote
Vref Posted December 18, 2010 Author Report Posted December 18, 2010 Quote: Mcstealth  Pep Boys. Belgium. Piloto, that was funny. Quote
thinwing Posted January 6, 2011 Report Posted January 6, 2011 go to aircraft spruce and download there catalog...the u channel is under finishing supplies...kpc Quote
