I went to go fly my 78 J today and noticed that there was a good bit on oil under the plane , looking in the oil fill door I couldn't see where the oil was coming from .  So I removed the cowling and started cleaning up the oil.  When I cleaned the oil off the mag I noticed it moving very easily . I  Called my mechanic over to retime the mags , but they just wouldn't come into time.  So we pulled the mags and sent them off for an overhaul .
It was odd timing, pun intended, that the mag had come lose and both sides went bad all at once .  I'm just glad it happened on the ground !
That challenge is so old, people have forgotten about it.  But it hasn't changed.
They haven't invented a reusable lock washer yet...(?)
1 hour ago, mike_elliott said:
Clarence, do you know why Loctite is frowned upon by the powers who govern the installation universe of F * r * sin(theta)?
Mike,
While its not really standard practice, but certainly a dab of blue loctite would work as well.
I would think that acrylic glue might be temperature sensitive to elevated temps.  Check the operating temperature range for the lock tite materials prior to use...
I only looked up one, 302°F was it's limitation...  (two part epoxy version)
then I looked up Loctite red.  They said service temperature is 300°F.  To remove parts that have been glued with the red, heat to 482°F is recommended.
http://www.loctiteproducts.com/tds/EPXY_HEAVY_tds.pdf
http://www.loctiteproducts.com/threadlockers.shtml
finally read about the blue... similar temp limitations there as well.
http://www.loctiteproducts.com/tds/T_LKR_BLUE_tds.pdf
How hot can a Magneto mounting bolt get?  About the same temperature as the engine's oil temp?
