jetdriven Posted November 12, 2016 Report Posted November 12, 2016 i think Mooney has more restrictive limits on the spars, like .005" , which is nothing.
Hyett6420 Posted November 12, 2016 Author Report Posted November 12, 2016 2 hours ago, jetdriven said: i think Mooney has more restrictive limits on the spars, like .005" , which is nothing. Ill check. Thanks. Not even sure if it is the spar yet just a phone conversation about corrosion in the left tank by the spar. andrew 1
Hyett6420 Posted November 17, 2016 Author Report Posted November 17, 2016 Ok so herewith some pics of the corrosion in the left tank. Is this on the spar and spar cap? I cant work it out to be honest. Do I need a new wing etc etc. Ideas? (PS I need to sleep tonight )
rbridges Posted November 17, 2016 Report Posted November 17, 2016 I guess I'll be the first to ask a probably dumb question. Is the gas tank corrosion because the tanks were left empty for an extended period of time? My orientation is off, so I'm not sure what's on the other side of these areas.
Hank Posted November 17, 2016 Report Posted November 17, 2016 If that's the bottom of the tank, isn't that the wing skin with the bulk of the corrosion on it? Where are the thick pieces of metal riveted on, to the front of the tank, the rear of the tank, or the inboard edge? I think the spar forms the rear wall of the tank. Clarence would be a good resource, or Paul Beck; they may recognize the bits from seeing them before, especially Paul. Good luck with this! Resealing is painful enough, I did that in 2010.
Hyett6420 Posted November 17, 2016 Author Report Posted November 17, 2016 1 hour ago, rbridges said: I guess I'll be the first to ask a probably dumb question. Is the gas tank corrosion because the tanks were left empty for an extended period of time? My orientation is off, so I'm not sure what's on the other side of these areas. to my knowledge i dont believe they have ever been left empty.
KSMooniac Posted November 17, 2016 Report Posted November 17, 2016 What is visible doesn't look terrible, but I'd be more concerned with what is under the caps that you cannot see. You might need to get a DER or Mooney engineering involved, I'm afraid.Sent from my VS985 4G using Tapatalk
thinwing Posted November 18, 2016 Report Posted November 18, 2016 On 10/28/2016 at 1:52 AM, Hyett6420 said: And so it has begun interior out with two mechanics umm proving that when the cats away..... AL flight controls removed and being prepped for the gel paint remover I hope the anaesthetist is good and doesn't let her feel any pain. Andrew You two need to decide who's in command and which way you are going!
Hyett6420 Posted November 18, 2016 Author Report Posted November 18, 2016 Just now, thinwing said: You two need to decide who's in command and which way you are going! No matey its more worrying than that, these two are two of the engineers from aeroskill. Their boss was away that day when the photo was taken. Neither are pilots, just engineers, i am not sure whether that is fortunate or not.
markejackson02 Posted November 22, 2016 Report Posted November 22, 2016 Got the Dec Aviation Consumer today. The airplane review is the 201 and what do you know G-OBAL was the Scheme Designers line drawing. 1
thinwing Posted November 22, 2016 Report Posted November 22, 2016 just curious ,but on initial ATC callup..it's " Gulf Oscar Bravo Alpha Lima,correct..?..than what alpha Lima for short....JUST SOUNDS LIKE A MOUTHFUL TO ME.SO HOW COME NO NUMBERS .
Hank Posted November 22, 2016 Report Posted November 22, 2016 Just now, thinwing said: just curious ,but on initial ATC callup..it's " Gulf Oscar Bravo Alpha Lima,correct..?..than what alpha Lima for short....JUST SOUNDS LIKE A MOUTHFUL TO ME.SO HOW COME NO NUMBERS . Same reason Canada and Europe ain't got no numbers. Just like their accents and funny spelling (really, "aluminium"??), it's just how they do it over there. Long, skinny license plates in their cars, too. And a different sense of "humour."
Hyett6420 Posted November 22, 2016 Author Report Posted November 22, 2016 42 minutes ago, Hank said: Same reason Canada and Europe ain't got no numbers. Just like their accents and funny spelling (really, "aluminium"??), it's just how they do it over there. Long, skinny license plates in their cars, too. And a different sense of "humour." London Centre (note the spelling) Golf Oscar Bravo Alpha Lima, passing flight level 060 for 080. After that it is Golf Alpha Lima. Now ACTUALLY you guys are the odd ones out. Most other countries to my knowledge use 1-2 letter country identifier (in your case N) and then a series of letters. If you think about it logically you can get more combinations with letters for a shorter registration than you can with numbers as there are 26 Letters versus 9 numbers. So..... the maximum you can get for 4 digits in the USA with numbers is N0000- N9999. While with Letters you can get NAAAA-NZZZZ. As for a mouthful to say Golf Alpha Lima is eaiser to say and takes up less frequency time than (if callsign is N4444DB) four four delta bravo, Ne c'est pas? Or in Latin Quad Erat Demonstrandum. As for spelling hmm you speak English guys, you just can't spell it correctly.
Hyett6420 Posted November 22, 2016 Author Report Posted November 22, 2016 3 hours ago, markejackson02 said: Got the Dec Aviation Consumer today. The airplane review is the 201 and what do you know G-OBAL was the Scheme Designers line drawing. Wow that's amazing. What's that publication called and is there an online link?
Hank Posted November 22, 2016 Report Posted November 22, 2016 Andrew, we use N + 5 alphanumeric characters, except some have only three or four. I learned in N55212, now I fly N444DJ. A friend has N2HJ. So it's not very standard here. And we have no problem being the odd man out. The magazine is Aviation Consumer, here: http://www.aviationconsumer.com Happy reading! 1
Hyett6420 Posted November 22, 2016 Author Report Posted November 22, 2016 Hi Guys A quick update, Aerocomfort has finished all the interiors work and that is being shipped to Aeroskill in the next few days once you get over celebrating the end of the presidential race with Thanksgiving. (Except Clarence . ). Glareshield Front seats note pneumatic lumbar support Rear seat backs Odds and sods rear roof liner Front roof liner rear seat pads Side panel inserts Front side panel Yokes ill post pics of the stripped aircraft in seperste post. Am very happy with aerocomfort and aeroskill so far. 4
Hyett6420 Posted November 22, 2016 Author Report Posted November 22, 2016 We visited Aeroskill today in Holland. Now there is a separate thread going on somewhere about why we have Money's but.... I woke at 04:30 to get taxi to train station for 5:50. Caught train to London Stansted (as close as Heathrow etc to London) and caught 08:40 flight to closest airport to Aeroskill that accepted Commerical traffic, Eindhoven. Landed at 10:40 local, security problem meant we could not disembark for 1:30. Eventually got to Hertz desk. No car waiting despite gold member. Eventually got to Seppe and Aeroskill at 13:00 in time for lunch. . All in all 7 hours train to destination rather than 1:30 in the Mooney. Grrr Anyway Aeroskill are doing a great job and have gone over the aircraft with a tooth comb. Very thorough and well documented. Baby has been stripped of paint and is ready for paint application. Buffed and minor nicks etc dealt with. Aeroskill are an MSC and I can see why. Having known various maintenance organisations they give a level of confidence that I have not felt before elsewhere to the same degree. On leaving Seppe the sun was setting check this out taken on an iPhone with just point and click 2
Andy95W Posted November 22, 2016 Report Posted November 22, 2016 Andrew- what was the resolution on your fuel tank corrosion? Within limits? Beautiful interior pieces, BTW. 1
Hyett6420 Posted November 22, 2016 Author Report Posted November 22, 2016 Just now, N1395W said: Andrew- what was the resolution on your fuel tank corrosion? Within limits? Beautiful interior pieces, BTW. Yes we believe so. The meeting today was to discuss work progress so far and whether to look at the right tank as well. We decided to clean the right tank as well. The corrosion guy is looking at the corrosion tomorrow. Paul Beck felt it was nothing to worry about and they see it regularly. I'll keep you all posted on outcome. Will know in a week or so. Andrew 5
XXX Posted November 22, 2016 Report Posted November 22, 2016 Very well done! I'm jealous. Can't wait to see it all come together. 1
Hank Posted November 23, 2016 Report Posted November 23, 2016 I'm very curious about the new paint scheme. It must be something else if the drawing for it received coverage in a national magazine. 1
carusoam Posted November 23, 2016 Report Posted November 23, 2016 Is the objective something simple, like.... Make GOBAL brand new again? Best regards, -a- 1
Hyett6420 Posted November 23, 2016 Author Report Posted November 23, 2016 5 hours ago, carusoam said: Is the objective something simple, like.... Make GOBAL brand new again? Best regards, -a- Something like that. Make her the best maintained Mooney in the european market. It is interesting the little things the MSC picked up like a leaking inlet gasket into cyl 1, a tiny little blue smudge on the inlet gasket, easy fix but not picked up by my engineers at its annual. These things matter and it is comforting to know they are being found and addressed. 2
Hyett6420 Posted November 23, 2016 Author Report Posted November 23, 2016 14 hours ago, Hank said: I'm very curious about the new paint scheme. It must be something else if the drawing for it received coverage in a national magazine. Patience and you will see her in all her glory not just a few sketches in a mag.
