I'm curious on which one people feel gives a better understanding of your airplane.  I have about 20 hours in my Mooney, and can't say that I'm 'comfortable' with it yet.  Knowing that an instrument rating will help with 'precision' while a commercial rating pushes the pilot/airplane unit towards the edges of the envelope; which one would you conquer first?  The current plan is to get both...but looking for input.
IMHO the commercial ticket is mildly helpful, and the instrument rating has a value of about 15 on a 1 to 10 scale.
Unfortunately, the effort to achieve them is proportional.
  • Like 5
Put a few hundred hours in the plane, then start the rating which will give you more utility.
IR then CR is the standard progression, a CR without an IR is very limiting. There are prerequisites to both so read the FAR's, the one that comes to mind is the 50hrs of x-country for IR, so doing IR knocks out some for the CR as well.
you can do both at same time and get both ratings in same check ride....at least it used to be that way years ago.....
I agree with Don.  The important one (and more technically demanding) is the instrument ticket.  Getting commercial done after it should be easier (so I am told).  I do not have a commercial rating - only an instrument rating.
The IR is personally useful.  The commercial is fairly useless by itself.   --So, get the IR first.  When you have recovered and want to build your VFR skills back up, get the CR. --I'm actually curious if one could find a job with just an IR and CR?   --Maybe as an ag pilot if you have lots of tail dragger time, but otherwise, I don't see it.
The precision in aircraft control required for the instrument rating easily transfers over to the Commercial Rating. The Commercial Rating is just an advanced Private Rating requiring tighter tolerances and 4 new tasks; 1. Steep spirals, 2. Chandelles  3. Lazy Eights. 4. Eights on pylons.  Also, a power off landing to a designated point and touchdown within 200 feet of that point.
2 minutes ago, N201MKTurbo said:
I got my instrument in '86, I got my commercial last night!
Congrats
Thanks for all the replies.  I don't know why, but I thought there would be less agreement on the issue.
There's a long history of standardization on this one because the IR has way more immediate utility.
But other than that, I have always thought the standard progression of IR then commercial is so the instrument pilot will learn how to fly visually again. I recall flying years ago with someone after he just got his IR - couldn't find an Interstate below us in CAVU with 100 miles visibility without taking VOR cross-radials :D
Congrats!  I'm assuming you used your Mooney?
I did.
I couldn't get a check ride in Arizona and I had to go to Hillsboro (Portland) OR this week to do some work at Intel, so I called around up here and got a check ride. So I flew the Mooney up here and did it.
The examiner said that he has never given a check ride to someone with their own plane, or someone with 6000 hours (actually 5271). He said I was his 52nd check ride in the last 90 days.
May be a great subject for a new thread!  Interested in hearing the rundown on what the examiner had you demonstrate and what was included in your oral.
