d0tnet Posted April 27, 2016 Report Posted April 27, 2016 Located this under the panel inside of my J. What is it? Is this a shunt for the ammeter?
MB65E Posted April 27, 2016 Report Posted April 27, 2016 Well It is not a shunt. Looks like the battery master solenoid. I didn't think think they were under the panel in the J. -Matt
takair Posted April 27, 2016 Report Posted April 27, 2016 It's a solenoid, a giant relay, likely for master power. That power wire tie wrapped to the cable, I recommend seperating them. When that cable chafes through the insulation on the power cable you will have a big problem on your hands. There is a lot going on in the photo, including a coax crossing over the solenoid. Sorry to pick at it, but I would hate for you to have problems later that are easily cleaned up now. 1
ArtVandelay Posted April 27, 2016 Report Posted April 27, 2016 Master relay is by the battery in my J, I would guess that's the starter relay.
StevenL757 Posted April 27, 2016 Report Posted April 27, 2016 If you're referring to the cylindrical-looking part with the sticker, that is indeed a relay. If a 24-volt airplane, it's a Kissling Part# 26.57.01 (a 300A 24-volt relay to be exact). Mooney sells them for over 1AMU, but there's a source literally just down the road from me that will sell them for about $475 each. If you need a 14-volt one, price is similar, but not certain of the part number...can't see that sticker too well from your pic. i believe George asked the same question in a similar post last year for his Eagle. Let me know if you need further guidance on procuring one.
d0tnet Posted April 27, 2016 Author Report Posted April 27, 2016 Thanks for the feedback guys, it seems like the consensus is that it is the starter relay. I concur it is a wire mess right now, having avionics shop start straightening it out. I am also having them install a voltammeter. However they can't seem to find the ammeter shunt anywhere. I thought I heard the typical location to be under the panel in the upper right side. Any thoughts where it could be buried? Sent from my XT1254 using Tapatalk
Yetti Posted April 27, 2016 Report Posted April 27, 2016 10 hours ago, takair said: That power wire tie wrapped to the cable, I recommend seperating them. When that cable chafes through the insulation on the power cable you will have a big problem on your hands. There is a lot going on in the photo, including a coax crossing over the solenoid. Sorry to pick at it, but I would hate for you to have problems later that are easily cleaned up now. ^^^^^ The over use of ty wraps and then the under use. That braided wire down low should not be that close to the lower terminal. The silicone protective boots over the main terminals are for accidental strikes not for things to be laying against. There also looks to be a control wire down around the mounting base that is could be the energize wire. That should be rerouted. It might be the ground wire to the relay, then it is probably OK. I put myself through college doing 2 way radio work. Summer time sweat along with 24 volt cement mixer trucks. Dropping a wrench across a B+ will get your attention. You don't want to have that happen under a panel while flying along. 1
Yetti Posted April 27, 2016 Report Posted April 27, 2016 The schematic I am looking at has a filter on the Alternator circuit and a Shunt on the Alternator Circuit. The Low voltage detector is downstream of the shunt that then goes into the Accessory Panel plug.
N601RX Posted April 27, 2016 Report Posted April 27, 2016 Its not a starter relay, it is a continuous duty type. Based on its location its likely the relay for an avionics bus. You should be able to follow the control wire back to a switch and see for sure. 1
d0tnet Posted April 27, 2016 Author Report Posted April 27, 2016 1 hour ago, Yetti said: What year and model number J? 84, 201
ArtVandelay Posted April 27, 2016 Report Posted April 27, 2016 3 hours ago, StevenL757 said: If you're referring to the cylindrical-looking part with the sticker, that is indeed a relay. If a 24-volt airplane, it's a Kissling Part# 26.57.01 (a 300A 24-volt relay to be exact). Mooney sells them for over 1AMU, but there's a source literally just down the road from me that will sell them for about $475 each. If you need a 14-volt one, price is similar, but not certain of the part number...can't see that sticker too well from your pic. i believe George asked the same question in a similar post last year for his Eagle. Let me know if you need further guidance on procuring one. You can buy a starter or master relay from Spruce for $70.
KSMooniac Posted April 27, 2016 Report Posted April 27, 2016 The shunt is likely on the right side, just behind the firewall. It is hard to access. That was the location for my '77 and '81 and I expect yours is similar, but wouldn't swear to it. There is a small aluminum "shelf" with electrical bits installed there, and it has three screws that come through the fuselage skin to help support it. 1
d0tnet Posted April 27, 2016 Author Report Posted April 27, 2016 1 hour ago, KSMooniac said: The shunt is likely on the right side, just behind the firewall. It is hard to access. That was the location for my '77 and '81 and I expect yours is similar, but wouldn't swear to it. There is a small aluminum "shelf" with electrical bits installed there, and it has three screws that come through the fuselage skin to help support it. Finally located it, thanks for the help Scott - you always give good insight! 1
Yetti Posted April 27, 2016 Report Posted April 27, 2016 sorry I meant serial number The schematics are by serial number. I found the J ones online here: http://mooney.free.fr/Manuels%20M20J/M20J/Mooney%20Service%20Manuel%20M20J%20Vol.%202%20of%202.pdf 1
d0tnet Posted April 27, 2016 Author Report Posted April 27, 2016 11 minutes ago, Yetti said: sorry I meant serial number The schematics are by serial number. I found the J ones online here: http://mooney.free.fr/Manuels%20M20J/M20J/Mooney%20Service%20Manuel%20M20J%20Vol.%202%20of%202.pdf Awesome- thank you! Learning everyday...
