6 hours ago, georgematthews said:
Do you have NLG doors for a F model? Needing LH and RH. Part numbers I have are 55005-503 & 55005-504.
I may possibly have a set of NLG available soon off my 75 M20F (they are undamaged). What are they worth?
I believe the price from Lasar is $310.95 for each side. I would be very interested in these...there's several parts I need that I am having trouble finding. Maybe you could check what you have and see if you have a bracket (P/N 950099-003) and a tube (P/N 340155-219). If you have any of these, let me know. You can reach me at 937-840-0624. If I am not available, you can speak with Cody. He is aware of all the parts that I need.
If you can get nose gears doors for that price I would go with LASAR. (That sounds like what I would expect to pay for the just the skins)..... Mine wont be available for at least another month anyway. (Most nose gear doors for the F usually are 5 to 8 hundred a door that I have seen on ebay anyway)
Edited by Mooney_Mike
You're exactly right. I just asked Cody about that and he said that price was just for the skins. My apologies on that one. If those do become available, let me know and I'm sure we can work something out. And if you see that you may have those other parts I mentioned, I would appreciate it greatly if you would give me the option to buy those from you. Again, sorry about the confusion on my part about those doors!
I'm doing the Lopresti super 201 cowl STC and that comes with new nose gear doors. That's the only reason I will be selling my old doors. The other parts I assume will still be used.. I will let you know when they are off the plane, it's out of my hands right now.
Understood. Just keep me in mind. Thank you for your time.
  • 2 weeks later...
Do you still have that one piece belly
I have a 77J model
How much are you asking?
Thank you
Eldon
call me at 780-975-8598
On 1/31/2017 at 0:05 AM, LANCECASPER said:
Acpartswhse was parting out a fairly late J model so it should be a factory one piece belly
What is contact number for Acpartswhse ?
Eldon,
Jerry is who you are looking for.
His contact info can be found next to his MS handle...  he has a lot of Mooney parts in trailers...
use the search box for ACpartswhse Jerry,   you should be able to find him this way.  He posts his phone number as well...
where have you been, how is Jezzie are you still together? :)
Hows this...?   I tried to copy his phone number, its in the thread...
Edited by carusoam
  • 7 months later...
On 10/11/2017 at 7:24 PM, Georgethenault@gmail.com said:
looking for a trim interrupt switch for a 79 k
also a cdt/ tit guage
I've got a TIT guage, but it's from an 87 252 so came out of a 28 volt airplane.
  • 2 weeks later...
Do you still have the cluster Gauge pictured on top with the cannon plug and individual gauges? It looks like you wanted $50.00, if so I'll take it.
Mhemperly made an offer April 26 2016 for $50.00  Regardless of that what do you want for the cluster gauge. You posted a picture of two units sitting on top of each other.
  • 2 months later...
I would love the yoke trim switch that goes to fen KAP 150 in my  1982 J?  Also looking for right side brakes for the same 82’J
thanks!
  • 2 months later...
I'm looking for a left rear upper exhaust riser and an inside door handle for a74 F model. Any chance you might have them?
Gerbil
I’m looking for one serviceable paramount brake cylinder or 2 of the later version that’s equivalent.
Gerdes A-110-37
Cleveland 10-49
Cleveland 10-24D
One of my paramounts losses pressure when I slowly apply the brakes. Tried the re-build kit with no luck.
Thank you
Hi Jerry,
I am looking for a Whelen strobe light power supply that is in operational condition, to replace the one in my 1990 M20J that has gone Tango Uniform.  The model number is A490ATS-DF-14 to 28.  Thanks - Hank
