Guest Mike261 Posted December 12, 2015 Report Posted December 12, 2015 I just installed a jpg 900... so i have all this stuff. don't know what anything is worth, will research later. thought i would make it available here first. ping me. mikeut b Quote
Tony Armour Posted December 17, 2015 Report Posted December 17, 2015 What is the sending unit/sensor, bottom picture ? Quote
Guest Mike261 Posted December 19, 2015 Report Posted December 19, 2015 fuel pressure or oil pressure...not sure. either way they are both oil pressure senders. my fuel pressure sensor failed and the only available replacement was an oil pressure sensor...it indicates less fuel pressure than actual as the bandwidth is different. This situation is what led me to the JPI 900, i was quoted a replacement fuel pressure sensor from mooney and it was over six grand and 56 week lead time. the used market was no better. All the gauges were old and flaky, now its pretty sweet. mike Quote
Tony Armour Posted December 21, 2015 Report Posted December 21, 2015 Does the fuel flow piece have... I guess it's called the transducer ? Quote
Guest Mike261 Posted December 21, 2015 Report Posted December 21, 2015 8 hours ago, Tony Armour said: Does the fuel flow piece have... I guess it's called the transducer ? The Shadin box i assume your talking about? yes, its all there. worked fine when it came out. it has a flow sensor, the box and some connectors. I dont have the stuff yet its still all in a box at the airport and i havent had time to collect it and inventory it. mike Quote
M20F-1968 Posted January 26, 2016 Report Posted January 26, 2016 How much do you want for the Shadin fluel flow? john.breda@gmail.com cell (617) 877-0025 John Breda Quote
