Jolie's video of the Tahoe fly in got me to thinking about securing a Mooney on a windy ramp. Are there any gust locks available, or is there any technique that people use? Tie it up with a seatbelt like a Piper maybe?
Buy a 40 inch long, Flat wide bungee with plastic j hooks on the ends. Hook on the seat fwd/aft adj. bar of east seat and through and/or around the inboard horn of each control wheel. Works great and is cheap. Just dont takeoff with it on.
Quote: DaV8or
These look pretty good. How does it attach to the panel. It's not quite clear from the photo on the website. Do you have to attach anything to the plane?
I ahve a gust lock from Aircreaft Spruce. When I lived in So Cal, we would see wind for 3 days, 60mph+ was probable. This gust lock grabs the rudder pedals and the yoke. Locks all the controls tight. It works great.
Ron  a 69F
Ron  a 69F
Dave I have this one.
Ron
yorkgustlok.jpg 3. YORK GUST-LOK™
York Gust Loks the ultimate protection for your plane from wind and theft. It locks the control surfaces in a neu- tral position and prevents damage to control surfaces & tail caused by wind Gust loads. It is welded steel, fully ad- justable,
13-00863 YORK GUST LOK MOONEY GRUMMAN $149.95
Quote: Jeff_S
You see a strap that extends from the middle of the device toward the panel. For the Mooney installation, they provide a little "L" bracket that has the male side of a snap fitting already attached. There is a panel screw that you simple remove, slide the "L" bracket onto and replace. It's very easy...takes about 30 seconds to install. To utilize, I'll slide the right-side (fixed) loop over the yoke, snap the cross piece in place, and then tighten the left-side loop which pulls the yokes forward into a nice down position.
Go to home depot and buy a set of adjustable bungees for a few bucks. One attached to the two yokes keeps the ailerons neutral. One around the top of the yoke and clip it you the part of your seat you pull up on to get it to roll back and forth for the elevators.
I forgot that there are two different versions for Mooney...sorry about that. But as Jim says, they should be able to fix you up. I like it better than a bungee solution because, well, it's just more elegant, has the big REMOVE sign on it (although it would be VERY hard to take off without removing it!) and it just appeals to my general aesthetic. But it probably doesn't WORK any better than a bungee solution, I will admit.
One other thing I like about this as compared to the Gust-LOK or other solution that ties into the rudder pedals is that you can put it on while traveling, and the FBO can still tow your plane wherever needed as the nose-wheel and rudder pedals will still have full movement. So you don't need to leave your key or let them into your plane. I had a Gust-LOK for my Warrior and it worked great, but it did have that limitation.
