When I removed my long-wire ADF antenna, I gained over 200 kts. Removing the tie-down rings added another 50 kts. I'm thinking of removing the engine and prop because I think they induce a fair amount of drag.
Has anyone else tried this?
Just remember if you do that, you will want to install ceramic tiles to the under side. This will protect you from the heat upon re-entry.
I heard some crazy people turn their brakes upside down!
I was going to do that, but the extra 60 kts hardly seemed worth the work.
I am not really joking. The old time drag video someone posted earlier shows just how much drag things like a simple wire can produce.
Plus the book says to remove before flight.
Ok, you have my attention (I'm an engineer). What video? A link would be helpful.
Chris,
That makes me look pretty quick on the trigger!
My link starts on part IV...
I'm going to have to search for a few more parts...
Chris,
Only reason you beat me was because I was watching parts 1, 2 & 3! ;)
I just had this done during annual and actually gained 65 kts.  The increase should be worth it since you will arrive at your destination before your departure time!
I  think waxing the wings smooth is misplaced. We should be sanding them a little rough. After watching the video I removed the tie down rings too.
I watched the video, I am back to joking.
As for the admonition in the book, that is a Mooney CYA.
You can't blame them, someone gets beaned by a tie-down lug falling from 5000' there's going to be litigation.
Better hope you have both lugs when the feds come to check.
