BillC Posted October 10, 2018 Report Posted October 10, 2018 39 minutes ago, Txbyker said: Can't do that on an IO-550 I don't think. I need to speak to Don Maxwell. As I said in my previous post I replaced my mounts two years ago and although they were fine for a while I have the same sag as before. Lord mounts were the correct ones for my Ovation (also as specified by George). I did shim my 201 and it worked great. It seems there must be a similar fix for sagging Ovations. Any other Ovation drivers finding the same problem? Quote
hypertech Posted October 10, 2018 Report Posted October 10, 2018 2 hours ago, BillC said: I need to speak to Don Maxwell. As I said in my previous post I replaced my mounts two years ago and although they were fine for a while I have the same sag as before. Lord mounts were the correct ones for my Ovation (also as specified by George). I did shim my 201 and it worked great. It seems there must be a similar fix for sagging Ovations. Any other Ovation drivers finding the same problem? Maxwell did my pre-buy and said mine was normal. It was one of the items that I specifically asked about. If it turns out there is something to be done about it, that's great news even though it would have been nice to know back then too. Quote
carusoam Posted October 12, 2018 Report Posted October 12, 2018 Bill, Do you have the Hartzell prop and spinner...? The smaller dia. spinner makes the prop look like it is sagging... Hartzell didn’t have the proper size when I got mine... Best regards, -a- Quote
bradp Posted October 12, 2018 Report Posted October 12, 2018 Anyone see the bit about the engine mount redesign on the ultra? Seems like it may be the best part about it.... Quote
