There are a bunch of cheap dental scopes on the market now that work very well.  My IA friend got an obsolete one from a local dentist that has an S-Video interface, and he bought a cheap dongle to connect it to a laptop for viewing and image capture.  It works great, and you can record pics of your valves as often as you wish and track wear patterns for very little cost.
i've got a cheap Whistler-branded borescope with a skinny flexible head and straight ahead camera that is ringed with small LED lights.  It works great for looking at the pistons and cylinder walls as well as tight places in the airframe (like for the tail attachment AD a couple years ago).  It has a 45 deg mirror attachment for looking sideways, but it doesn't work for valves due to focal length issues.
I paid $10k for my intraoral dental camera 18 years ago.  Make me ill how cheap you can get them now.
:D There are new chinese USB versions out there for ~$100 that the Beechtalk crowd seems to like.  "Real" dental units on the surplus market and ebay seem to be in the same ballpark as well.
Mike Busch just indorsed the new Snap-on borescope($995) on his last webinar. I don't recall what model he said it was but mentioned it had great features. I have one of the cheap($79) China dental cams and it works perfectly with fantastic detail.
Does yours have a 90 degree lens, or can you only see "straight ahead".
It is 90 degrees. When borescoping through the spark plug hole I can angle it to see everything but the center of the piston. That I can see with a flsh light looking through the hole. Here is a post I made with some of the photo from it. In the first picture you can see the camera sitting on the box in the bottom left corner.
http://mooneyspace.com/topic/10433-ly-con-cylinders-arrived/?hl=%2Blcd-con+%2Bcylinder
Do you have a brand name; or is there some terminology for dental cams that will tell you it has the 90 degree lens.
