AJ88V Posted January 18 Report Posted January 18 no idea. it's on a pic of a 201 I'm looking at......
AJ88V Posted January 18 Author Report Posted January 18 It looks like the outer "blades" can move, but not any kind of speedbrake I've ever seen (and the listing doesn't call out speedbrakes). It appears to be painted the same dark metallic blue elsewhere on the plane. Plane has TKS, but don't think you'd put a not-aerodynamic element like that on top of the wing.
ArtVandelay Posted January 18 Report Posted January 18 It looks like the outer "blades" can move, but not any kind of speedbrake I've ever seen (and the listing doesn't call out speedbrakes). It appears to be painted the same dark metallic blue elsewhere on the plane. Plane has TKS, but don't think you'd put a not-aerodynamic element like that on top of the wing.Can’t you ask the seller?
toto Posted January 18 Report Posted January 18 +1 on the GoPro mount. I’d bet it’s stuck on with adhesive.
LarryAZ Posted January 18 Report Posted January 18 2 hours ago, varlajo said: A GoPro mount? It's an old gopro mount. I've got on on the ceiling in my plane.
AJ88V Posted January 18 Author Report Posted January 18 Thanks. Probably a GoPro mount based on consensus. Seems like an odd thing to take a picture of to sell an airplane. 1
OR75 Posted January 19 Report Posted January 19 A GoPro mount. If you want to take it out you can use a hair dryer or a heat gun
Jsno Posted January 19 Report Posted January 19 6 hours ago, OR75 said: A GoPro mount. If you want to take it out you can use a hair dryer or a heat gun Don’t use heat. You could change the temperature of the aluminum. Use a plastic scraper.
Marc_B Posted January 19 Report Posted January 19 It's a GoPro mount of course. I find that sometimes using dental floss wrapped around and tightened/pulled will separate under the adhesive. Take if off in the summer when it's been out on the ramp in the sun. A little 3M Adhesive Remover or GooGone would clean the residue off after removal, then clean and polish area with some WashWaxAll.
toto Posted January 19 Report Posted January 19 7 minutes ago, Marc_B said: dental floss Fishing line is also good for this 1
EricJ Posted January 19 Report Posted January 19 +1 that it should come off with dental floss or fishing line if you don't want to keep it.
