Hello all,
I am a soon to be Mooney M20C owner, (picking it up Friday). It is in desperate need of some panel upgrades. I am considering a GNX 375 for the ads-b/transponder and GPS. However, it currently has a STEC-30 I would like to keep for now. Does the GNX 375 have the capability to connect directly to the STEC-30 or is a G5 required also, or another converter of some sort? It is currently connected to an old Garmin 150xl with GPSS adaptor.
Thank you!
-Trent
I just had that quoted.  Stec 30 is in plane.   The work was for Install two 275s and a GNX375  From the shop "I am not aware of any additional adapter needed for the STEC30. We have done a few and only time an adapter is needed is with the G5s. "
How much was that quote roughly? I haven't got an install quote yet. The 275s are certainly what I would want but they are proud of them!
@Trenton W
@Yetti
sorry, I should read better.  If you have a gpss, it should work.  What is it currently using as a heading bug ? Do you have an hsi?
 Gpss will translate from the -375 to the stec.
8 hours ago, Ragsf15e said:
@Trenton W
@Yetti
2 hours ago, Trenton W said:
You’ll need to get a real avionics place to be sure, but the gpss should be fine between the-375 and the stec30.
21 hours ago, Trenton W said:
Hello all,
Thank you!
-Trent
The STEC is a rate based autopilot and gets its info from the STEC turn coordinator so you don't need a G5. The heading bug you have should still work.
