Hank Posted October 1 Report Posted October 1 On 9/29/2025 at 10:45 PM, Utah20Gflyer said: I did my private in a Cherokee. It’s the Ford Fiesta of airplanes. 7 hours ago, dkkim73 said: Hmmm. Toyota Celica? No, the base Cherokee, even Archers, is just a Fiesta. The Celica has always had too much get up and go.
Hank Posted October 1 Report Posted October 1 18 hours ago, Shadrach said: I have only flown formation with a C model. The difference in both climb and cruise surprised both of us. While it wasn't a formation flight, I took a friend to pick up his 75 F after AP work, a bit over and hour away. On the flight home, despite the 3-blade airbrake on my C, I kept his F in sight, and I was on downwind about the time he parked.
DXB Posted October 1 Report Posted October 1 A bit slow for a stock E. I take a strong principled stand against the folks here saying to put up with it - you didn't buy this thing to putt along at 143 - 148kts! You wanna be seen getting outrun by my well-modded C??!! How's that for a motivational pep talk? Cheapest speed mods are rigging it perfectly and waxing the wings. Make sure gear doors close fully. Timing advance in cruise from a Surefly will give you a clear benefit also for not too much money. The powerflow helped my C a good bit but may not do much for the E's engine/exhaust setup. The cowl closure looks nice but does nothing. Brake caliper rotation and flap gap seals are cheap mods that actually help a bit. Most other mods do very little. The 201 windshield is hard to find now and is a very expensive way to get a couple extra kts. Same with a 2 blade top prop. The windshield does make the cabin feel more spacious, improves visibility and perceptibly decreases prop noise. 1
AndreiC Posted October 1 Author Report Posted October 1 1 hour ago, DXB said: The cowl closure looks nice but does nothing. Brake caliper rotation and flap gap seals are cheap mods that actually help a bit. Most other mods do very little. The 201 windshield is hard to find now and is a very expensive way to get a couple extra kts. Same with a 2 blade top prop. The windshield does make the cabin feel more spacious, improves visibility and perceptibly decreases prop noise. Thanks, Dev. I spoke to the folks at LASAR and decided to try to install the flap gap seals (at least) at my next annual. (At the moment they are trying to get things squared away with the FAA after their move to Oregon, and are not selling any of the kits; but they should be available in a month or so.) The other two kits they recommended were the dorsal fin vertical seal and the wing root fairing. Anyone have any experience if these two do anything to improve speed?
Pinecone Posted October 1 Report Posted October 1 13 hours ago, Shadrach said: I guess I’ve never really considered that one might be able to set track records with a front wheel drive car. It seems fundamentally to be the wrong tool for the job. I’ve enjoyed lots of front drivers as street cars (Cooper S and Fiat Abart in particular) but I’ve never thought of the them as track cars… But then I don’t race, so what do I know? They set track records for THEIR CLASS. Not outright. LOVE my Fiat 500 Abarth. Hmmmm, 500 Abarth, E46 M3, E36 M3 LTW, Mooney M20K 252. Maybe a trend.
Paul Thomas Posted October 1 Report Posted October 1 11 hours ago, AndreiC said: Maybe as the OP I will add that whoever guessed Porsche 914 has my vote. That is my fun car Here is a pic of it. Born same year and month as myself. (That is the Porsche for CB's, 1/4 of the price of a 911...) I wanted to buy one as my first car but once my mother heard Porsche, it was swiftly ruled out. Back then you could get a rust free 914/6 for very little money. My argument that it was just like a WW Beetle was ineffective.
TheAv8r Posted October 1 Report Posted October 1 The only speed mod I have on my E is the cowl enclosure (LASAR), it has the 1-piece windshield (not J) but that's it. I get the same as you LOP, around 142-145kts TAS @ 65% power at 7.5-8gph, but ROP I will get 152-155kts TAS at 75% power, 12gph to be 150deg ROP. Book figures are actually like 160kts if you can believe it, but nobody is getting those numbers out of a stock E haha. If you're getting 148, it is a tad slow for an E, I've owned 2 and both had no problem hitting low 150s at 75% power. I routinely fly mine LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS.
AndreiC Posted October 1 Author Report Posted October 1 13 minutes ago, TheAv8r said: The only speed mod I have on my E is the cowl enclosure (LASAR), it has the 1-piece windshield (not J) but that's it. I get the same as you LOP, around 142-145kts TAS @ 65% power at 7.5-8gph, but ROP I will get 152-155kts TAS at 75% power, 12gph to be 150deg ROP. Book figures are actually like 160kts if you can believe it, but nobody is getting those numbers out of a stock E haha. If you're getting 148, it is a tad slow for an E, I've owned 2 and both had no problem hitting low 150s at 75% power. I routinely fly mine LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS. Well, it seems like there is about a 5 knot penalty on my plane for the 1970 model (with many exposed screw heads instead of flush rivets) and inefficient three blade prop. My best speed/fuel efficiency ratio for cruising seems to be 9.3 gph (peak EGT) at 8500 feet, 143 kts, 2500 rpm.
Hank Posted October 1 Report Posted October 1 20 minutes ago, TheAv8r said: I routinely fly [my E] LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS. That's very similar to the performance i get from my C at 9000 msl, WOT- / 2500 and leaned to peak or 25° Rich. No fuel flow installed, but i get ~8.4 gph from fuel pump to fuel pump. I do have the 201 windshield and guppy mouth closure, but also have a Hartzell 3-blade prop.
Shadrach Posted October 1 Report Posted October 1 2 hours ago, Hank said: While it wasn't a formation flight, I took a friend to pick up his 75 F after AP work, a bit over and hour away. On the flight home, despite the 3-blade airbrake on my C, I kept his F in sight, and I was on downwind about the time he parked. It’s a single data point between two planes. Certainly not a comprehensive model vs model comparison. We were running supplies to NC together. He departed 2 mins ahead of me and despite being within 100lbs gross, I passed over him about 9nm from the airport as I climbed through 6500 on my way to 8500. He was as surprised as I was at the climb and speed differential. I will likely start flying that C model while my F is down for upgrades. I’ll get a better idea of the performance differences after a few long cross country trips.
TheAv8r Posted October 1 Report Posted October 1 2 hours ago, AndreiC said: Well, it seems like there is about a 5 knot penalty on my plane for the 1970 model (with many exposed screw heads instead of flush rivets) and inefficient three blade prop. My best speed/fuel efficiency ratio for cruising seems to be 9.3 gph (peak EGT) at 8500 feet, 143 kts, 2500 rpm. Yeah, the 3-blade prop is going to come with a cruise penalty. I also have a SureFly and GAMI injectors on my plane so I can run it really smoothly LOP which will get me down to the 7.5gph range at the same speed.
DC_Brasil Posted October 1 Report Posted October 1 I don't know how my plane compares to MS members here. I have a 1990 J with no special mods (other than avionics) and removal of speedbrakes. Flying at 10,000 feet I usually get: - 139 Kts TAS @ 2.200 RPM LOP 7.5 to 8.2 GPH - 155 Kts TAS @ 2.400 RPM ROP 9.5 to 10.2 GPH According to Savvy analysis of my data I'm right at the average of the fleet (similar make/model/year/engine).
Chessieretriever Posted Friday at 11:38 PM Report Posted Friday at 11:38 PM Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine.
Paul Thomas Posted Saturday at 01:13 AM Report Posted Saturday at 01:13 AM 1 hour ago, Chessieretriever said: Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine. 135KIAS at 10,500 is ~160KTAS... I'd like to see those speeds out of my J (and like the C you're flying, I don't have the lower gear doors).
Slick Nick Posted Saturday at 01:33 AM Report Posted Saturday at 01:33 AM 1 hour ago, Chessieretriever said: Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine. Looks like that isn’t even at full throttle? Something doesn’t add up.
ArtVandelay Posted Saturday at 01:45 AM Report Posted Saturday at 01:45 AM Looks like that isn’t even at full throttle? Something doesn’t add up. You’re assuming the instrument is correct on a 60 year old plane.
Slick Nick Posted Saturday at 01:46 AM Report Posted Saturday at 01:46 AM Just now, ArtVandelay said: You’re assuming the instrument is correct. That’s exactly what I’m getting at. The numbers don’t add up.
Hank Posted Saturday at 02:02 AM Report Posted Saturday at 02:02 AM 26 minutes ago, Slick Nick said: Looks like that isn’t even at full throttle? Something doesn’t add up. 14 minutes ago, ArtVandelay said: You’re assuming the instrument is correct on a 60 year old plane. 12 minutes ago, Slick Nick said: That’s exactly what I’m getting at. The numbers don’t add up. He's showing just over 20" at 11,500; my C barely makes that at 10,000. And at 20"/2500 and 10,000 msl, I'm usually around 145-148 KTAS (indicating around 145 mph). 1
bonal Posted Saturday at 02:29 AM Report Posted Saturday at 02:29 AM (edited) This translates to approximately 147ktas which makes more sense. I honestly can’t tell you what the RPMS were but I normally cruise at 2400 even up high. I know that our little C models are amazing for the speed you get from 180hp but 160 knots does seem a bit questionable Edited Saturday at 02:51 AM by bonal Duh
ArtVandelay Posted Saturday at 10:46 AM Report Posted Saturday at 10:46 AM He's showing just over 20" at 11,500; my C barely makes that at 10,000. And at 20"/2500 and 10,000 msl, I'm usually around 145-148 KTAS (indicating around 145 mph).For those of us that fly in the south where air is warm and humidity is high, our performance will not match our northern counterparts. I routinely see a 10 knot difference in TAS between flights in PA (where he is) and flights in FL. Our engines are not making rated HP in hot and moist air, if you want bragging rights, move to where it’s cold and dry.
Danb Posted Saturday at 10:08 PM Report Posted Saturday at 10:08 PM On 9/29/2025 at 7:31 PM, Shadrach said: So speedwise, your E is well within the normal range for the model if not a tad on the slow side. The three bladed prop is not as efficient as a two blade. There are plenty of people who will tell you that it doesn’t make a difference and there are plenty that will tell you it’s costing you 5kts. You won’t have any idea unless you change propellers. The truth is, it doesn’t matter because from a practical matter, none of these planes are separated by that much in terms of speed. I have a 67F that I know it will do just over 150kts in cruise at just about any altitude under 10,000 feet. That being said, my current average GPS block speed as tracked over the last 5000nm is 144.9kts. It just recently fell below 145kts because of several trips under two hours that tend towards lower block speeds (for obvious reasons). What would I need to do to get a significant increase in speed? I’ve thought about this many times. Aircraft owners tend to assign a whole lot of value to things that really don’t make that big of a difference operationally. That’s why you’ll see people brag over a 7kt difference in cruise speed. The reality is that for me to realize a significant increase in time compression, range, and load carrying capacity, I would have to move into a high-performance twin or a turbine. Sometimes the best course of action is to recognize that what you have is delivering excellent, output value for the input. If you want to tweak your E to be faster, I think that’s an admirable pursuit, it may respond to some minor massaging. However, even if you were able to fettle and message it into 155kt cruiser, the time savings for most trips would be minuscule. I stopped wishing my bird was more than it is a long time ago and just decided to admire it for how well it does what it does. Well Ross I’ve got your answer, I’m not attempting to be a smart ass but providing my facts. Around about 1985 I had a very nice Cherokee 160, my instructor had a Mooney model E nice I became enamored with his speed when he passed me one Sunday on our way to lunch at Lancaster which is the home of Weber Mooney Service and Sales. I didn’t want him to pass me again so Mr Henry Weber a very nice honest man made me a great deal on a 1977 201 J which worked well until Mooney went into financial difficulties 1988 they offered planes at a huge discount over prior years but using direct marketing good ol Dirk Vandersee found my contact info and talked us into a looksee he flew a new 1988 up to Wilmington my wife said as long as it’s not red we can be nice and say no and take him to dinner. Coming down the ILS was a nice red and white J being new was faster and new equipment one problem nice Mr Weber wanted to know why I’d buy from Mooney passing him by not giving him a chance I politely informed him of the huge discount he mentioned son, yep I was young at one time but stupid, he said he will beat Mooney’s deal easy any time …why the heck would they cut my throat he said ..after all I’ve done to help the company. So Mr Dirk the deals off I’m dealing with Mr Weber, I still go there by the way, oh back to the E model and the need for speed I was talking to Ross about, well some 17 years later we wanted to do a lot more trips so along came a new red Bravo GX long range tanks the Mooney company again in financial difficulty …so I get my last great deal on a Mooney in my quest for speed like Andrei, unfortunately the company being somewhat the sleez they can be and I didn’t know Mooneyscape or any other social site to provide info that a Mooney Acclaim was being introduced I purchased from Premiere who didn’t let the cat out of the bag. Ultimately due to unscrupulous insurance agents I sold the Bravo believing I would’nt be able to get insurance after age 75, after selling the Bravo my lying agent found insurance and I ended up with the speed queen a Mooney Acclaim TypeS. Sorry Ross I really thought it wouldn’t be so voluminous to write up my question for speed like Andrei. 1
Echo Posted Monday at 12:11 AM Report Posted Monday at 12:11 AM Flew to Indy with my wife on Friday. Winds were benign. At 7500 with max MP and 2500rpm at 10gph groundspeed was 150knots. I am very impressed with some of your planes ability to achieve speed numbers LOP. My plane runs very cool (290-330 on cylinder temps), BUT starts stumbling below 9gph. Return trip this afternoon had turbulance at 6500 with a weird almost invisible layer that forced my higher. Wind was gusting from south and could not get over 145knots on return. Return flight took ten more minutes. I'm good with that. Andre, your 914 is beautiful. Love the paint. I was at a local chapter Pcar event and a member had heavily modded his 914 (spending over six figures!). It had Martini Racing colors. He also put a 911 type six gauge set up that was painted blue of exterior on the surround. A gorgeous example. He also has a 356 Super. 1
Shadrach Posted Monday at 07:50 PM Report Posted Monday at 07:50 PM On 10/4/2025 at 6:08 PM, Danb said: Well Ross I’ve got your answer, I’m not attempting to be a smart ass but providing my facts. Around about 1985 I had a very nice Cherokee 160, my instructor had a Mooney model E nice I became enamored with his speed when he passed me one Sunday on our way to lunch at Lancaster which is the home of Weber Mooney Service and Sales. I didn’t want him to pass me again so Mr Henry Weber a very nice honest man made me a great deal on a 1977 201 J which worked well until Mooney went into financial difficulties 1988 they offered planes at a huge discount over prior years but using direct marketing good ol Dirk Vandersee found my contact info and talked us into a looksee he flew a new 1988 up to Wilmington my wife said as long as it’s not red we can be nice and say no and take him to dinner. Coming down the ILS was a nice red and white J being new was faster and new equipment one problem nice Mr Weber wanted to know why I’d buy from Mooney passing him by not giving him a chance I politely informed him of the huge discount he mentioned son, yep I was young at one time but stupid, he said he will beat Mooney’s deal easy any time …why the heck would they cut my throat he said ..after all I’ve done to help the company. So Mr Dirk the deals off I’m dealing with Mr Weber, I still go there by the way, oh back to the E model and the need for speed I was talking to Ross about, well some 17 years later we wanted to do a lot more trips so along came a new red Bravo GX long range tanks the Mooney company again in financial difficulty …so I get my last great deal on a Mooney in my quest for speed like Andrei, unfortunately the company being somewhat the sleez they can be and I didn’t know Mooneyscape or any other social site to provide info that a Mooney Acclaim was being introduced I purchased from Premiere who didn’t let the cat out of the bag. Ultimately due to unscrupulous insurance agents I sold the Bravo believing I would’nt be able to get insurance after age 75, after selling the Bravo my lying agent found insurance and I ended up with the speed queen a Mooney Acclaim TypeS. Sorry Ross I really thought it wouldn’t be so voluminous to write up my question for speed like Andrei. I wasn’t trying to be a smart ass either. I should’ve included turbo singles in my list of potential upgrades to gain significant time compression. Indeed there is no question that a Type S has significant speed advantage over my little 4 cyl M20F. The challenge for me is that I also need payload for a family of four. So I can get more time compression or I can get better useful load or I can get more range from an NA single but if I want more of all three, it’s probably kerosene or high performance twin. I can put 800lbs in the cabin and go 500nm in under 3.5 hours with 1hr reserves. This leaves us room for the little ones to grow. That is the mission. I was not poo-pooing any one else’s aircraft choices only offering a rational for why 148kts is probably fine to live with and not worth obsessing over. My dad bought three Mooney’s from Henry Weber in the span of one decade. He has only nice things to say about the man. 3
AndreiC Posted Monday at 07:57 PM Author Report Posted Monday at 07:57 PM Well I got some real life data. Over the weekend I flew some long flights, from Madison WI to Santa Fe NM (two days, with a stopover in Lincoln, NE) and back (one day yesterday). On the way down I had some unforecasted headwinds (they had forecast headwinds to be 8-10kts at 16500, but they were more like 15-20kts) but made up for it on the way back (30-35kts tailwind at 15000). The overall distance covered was 1775nm in 12h10m, for a complete block to block average speed of 145.89 kts. Not so bad. I've been trying to figure out from this data what is a good guess of my block-to-block speed without wind is, and a rough estimate seems to be around 140-141 kts, so about 5 hts slower than @Shadrach's. Of course, the longer the legs the closer the block-to-block speed is to TAS.
AndreiC Posted Monday at 08:03 PM Author Report Posted Monday at 08:03 PM 9 minutes ago, Shadrach said: I can put 800lbs in the cabin and go 500nm in under 3.5 hours with 1hr reserves. Wow, your F really is a wonderful machine. What is the useful load? Over 1000 lbs? In my E if I put 800 lbs in the cabin I can barely fly 1 hour with 1 hour reserve... (but I have bladders and 3-blade prop, both of which add to the weight).
